The source menu wont clear from the screen, how can i fix this
    Top Expert:
  • Televison & ... Master
  • 75,157 Answers
A reset procedure might help. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Dec 06, 2016
How to enable the input of lcd
hi,
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
source.
( An image from the selected source automatically
displays).
Each time INPUT is pressed, the input source
toggles.
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
ok.
Dec 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tip
Motorola i1 Hard Reset
Resetting your i1:<br /><br /><span> <ol> <li>From the main home screen, tap menu</li> <li>Tap <b>Settings</b>, then <b>SD card & phone storage</b></li> <li>Tap <b>Master Clear<br /></b></li> <li>Tap <b>Reset phone</b></li> <li>Enter your password, then tap <b>OK</b> to confirm</li> <li>Tap <b>Erase everything</b></li></ol></span>If you cannot access the menu or your i1 is locked out then follow the source link for the hard reset at start up.<br />Source: <a href="http://www.phonegeni.us/index.php/Motorola_i1">PhoneGenius - Resetting Motorola i1</a><br />
on Feb 27, 2011 | Motorola Mobility i1 Smartphone
The screen is black, but i can hear the sound very clearly
press the menu button if the menu doesn't come up the tv needs to be repaired. If the menu does come up try a second source, such as a dvd player or a game system. If the issue is only with the original source such as a cable box or cable from the wall then the cable company would need to be called.
May 06, 2010 | InFocus ScreenPlay 61" Rear Projection...
Wont clear filter
If the clearing the filter screen will not go off then it is sure that compressor is not good.please check the compressor with vacuum gauge & make sure is has 13" HG of suction.
Aug 12, 2009 | Robinair Cool Tech 34700Z Recovery,...
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Viewsonic n4060w power but no menu or source selection....
hello, you will need to locate a service manual for it.
cd or downloaded it costs a few dollars but it is worth it.
if your going to open it might as well know what to check for.
you need it to service your set.
not processing signal, menu not displaying,
sound like internal board issues.
good luck hope this helps
good luck
hope this helps
Dec 21, 2008 | ViewSonic NextVision N4060w 40 in. LCD...
WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Jan 05, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Screen is black except briefly blue upon power on or putting source on "VGA"
Your backlights power inverter board is what causes this prob. It is a Darfon V144-001.
Dec 30, 2007 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Backlight
Unfortunately, the only way to change this is through menu options. Try going into a very well lit room, and then do the following: Menu-->settings-->display settings-->backlight
Nov 17, 2007 | Motorola Mobility V170
Televison & Video Logo
Top Televison & Video Experts
