Question about Samsung Cameras
I have Samsung NX3300 camera. The camera at times will not turn on for hours. And then it will turn on. I replaced a battery and it still happens.
My brand new samsung s760 camera wont turn on
Charge for 1 hour.
Pull battery's and see if they have power.
If Power is good Make sure they are in correctly
If Dead Replace battery's. ,
The only other thing it Might be, You said the Camera was New, But if the battery's hold a charge the Battery Door might have lost it's Contacts and the battery's won't work without it, It may have been returned to the store before you got it..
Nov 09, 2013 | Samsung S760 Digital Camera
Samsung L100 camera, battery charger shows battery is fully charged, camera powers on, lens extends then immediately retracts and camera beeps three times
it sounds like a faulty battery try testing it with another battery and see if the problem persists if not then get a new battery,
let me know how it goes,
Jul 31, 2010 | Samsung L100 Digital Camera
Samsung s1065 beeps 3 times nothing else. only 6months old wont turn on. bought recommended batteries, still wont turn on
One of the 4 conditions a-batteries are inserted incorrectly b-batteries have died and need to be replaced c-you have selected the wrong battery type option on the Setup2 menu d-your camera is malfunctioning and needs servicing.
Jul 19, 2009 | Gateway DC-M40 Digital Camera
My samsung L830 camera has jammed with the lens open and
Just had this happen to my L100. First, take out the battery and wait a couple hours for everything to cool down and discharge. Then place the battery back in. Then plug the USB cord into the camera and PC. Then turn the camera on and it should be okay. Just worked for mine.
Jul 15, 2009 | Samsung Digimax L830 Digital Camera
Put new batteries in, camera bleeps three times & switches off
hi meeshfriel,
The battery might be damaged. try recharged the battery at least 2 hours maximum of 4 hours. If the problem persist it is your battery needs to be replaced......
Thanks.
jonags
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Start up
Try leaving the batteries out for 12-24 hours and then try again. If it still does not work then your lens is jammed and needs to be replaced or reajusted. Hope this helps. "Try the 24 hour first it does help some times.
Mar 28, 2008 | Kodak EasyShare One Digital Camera
TROUBLESHOOTING
Samsung User Support will advise whether this is replaceable under warranty or a recall for faulty manufacture
Dec 26, 2007 | Samsung Digimax A7 Digital Camera
POWER DRAIN
You said it 'Not able to fix the problem' Extended warranty that send stuff away to third party repairers are a waste of time. That is because there is nothing to repair or parts to repair with. Go to Samsung Tech Support- tell them the tale they will either repair it free - or offer you a replacement for a low price.
Jul 14, 2007 | Samsung Digimax V800 Digital Camera
Cameras Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
