Question about HP Color Laserjet Cp2025 Printer Laserjet 600 X 600 Dpi Laser 40000
How to reset and/or clear error message on an hp cp2025
  • 1,381 Answers
This sounds like bad jetdirect card causing it..problem is new HPs have them integrated and they can not be replaced. If a firmware update does not fix it, then a call to HP would be the best bet
Posted on Dec 20, 2016
4 Suggested Answers
  • 567 Answers
SOURCE: HP CLJ CP2025 with a 57.01 error. Is it a fan
Hi you should uninstall the printer drivers and reinstall the again,if you do not have the software CD click this link to download the latest updates and drivers for you printer,
Posted on Jul 29, 2010
  • 118 Answers
SOURCE: Dear Expert, I Have a new
This indicates that there is a main motor error.
First check that all the toner cartridges are ok by removing them and then rotate gearing on toner cartridge just a small way to see that it is not stuck. I have found generic cartridges do seize at times and this could give the error.
Also remove fuser assembly and turn the gearing to make sure that is ok.
If all of the above are ok, then you have a defective main motor.
Posted on Jun 02, 2011
SOURCE: hp cp2025 marca error limpiando
Hi, you may try this:
on the control panel you should change the settings, like it shows---> Default Paper Size: A4 or Letter
Default Paper Type: Plain
Manual Feed: Off
Tray 1 Size: Any Size
Tray 1 Type: Any Type
Tray 2 Size: A4 or Letter
Tray 2 Type: Heavy 111-130g
Tray 3 Size: A4 or Letter
Tray 3 Type: Heavy 111-130g
Posted on Oct 26, 2012
I would suggest replacing the roller then. Laser printers are fully serviceable unlike inkjet printers which have a set life span. You should contact HP and describe the error and they can make you a recommendation on the parts (or service kits) required to remedy the issue.
Nov 15, 2013 | HEWLETT-PACKARD Office Equipment &...
Hp color laserjet cp2025 10.1000 supply memory error
Hp color laser jet cp2025 10.1000 supply memory error solution
May 30, 2012 | HP Office Equipment & Supplies
Hp cp2025 remove shipping lock
I had same problem with black and blue cartridges. I did all recommendations -- return to factory setting ( no help). Shake cartridges REALLY hard ( no help); reinstall printer/ driver ( no help). What finally WORKED was SWAPPING the cartridges around ( for ex. put red in black spot, blue in yellow). I then got an error message ( b/c in wrong spot). Then I placed them back in correct spots and it WORKED !!! NO more error message that the ship lock was on !!! And this worked with generic cartirdges.
Nov 19, 2011 | HP Laserjet Cp2025n Printer
HP Color Laser Jet CP2025. Replace Supplies message on screen and can't get it off. Put in a new print cartridge. Message still won't go away. Please advise how I can get a User Manual for this...
HP Color LaserJet CP2025 - "Replace Supplies" message.
black cartridge is blinking. Printer won't print and message will not go away. Any suggestions?
Nov 09, 2010 | HP Office Equipment & Supplies
Printer model HP Laserjet CP2025, at display panel appear 'supply memory error'. How to solve it. Thank you
This is a problem with the toner cartridge, check the code at the end of the error message and that will tell you which toner is defective.
Aug 10, 2010 | HP Laserjet Cp2025n Printer
HP Color Laserjet Cp2025 Printer Laserjet 600 X 600 Dpi Laser 40000 Logo
101 people viewed this question
Ben Johnson
