Washing machine fabric softner problem
Hi i have a indesit wia 121 washing machine that appears to no longer take the fabric softner into the wash, any help would be great thanks
  • 221 Answers
Remove the detergent compartment itself and clean it all up. Usually such problem is caused by blocked hole for softener. otherwise check coil continuity of the orange coloured water inlet valve
Update me about your progress
Posted on Jul 25, 2009
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Indesit WM12 Front Loading Washing machine. The fabric softner poured into the tray never dispenses into the wash load. I even find water in the tray as if something is clogged. Help!
Thanks for choosing FixYa and welcome to the site. Your tray has a hose that leads the fluid into the washer. You need to clean this hose out. Take out the tray and clean the hose. This should solve your issue.
May 07, 2011 | Indesit Washing Machines
Hi i need to order new shock absorbers for my washing machine indesit wia 121 uk but there are two types both look the same and i have no part no's on my old ones how can i tell? is there a differance?...
Hi from retired Englishman in SW France @21:31 Sat evening -'cos there's nothing on TV!
You will need the make, model and possibly serial number as reference. These are normally found on a label on the underside of the top of the door surround.
Whoever you are ordering from should be able to supply the correct ones.
Cheers,
John C
Jan 29, 2011 | Washing Machines
Fabric sofetener will not go into washer
Here is a tip that I wrote about what I found out about the fabric softener notdispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going intowasher
heatman101
Sep 18, 2010 | Indesit WA 125 Front Load Washer
The frabic softner dispensor is not releasing the softner in the washer.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 05, 2010 | GE WSXH208A Front Load Washer
Changine a heating element on a washing machine Indesit WIA 101
Sam. The small nut and bolt which protrudes between the element ends should be loosened but not taken off. Press on the bolt, which will relax the compression on the rubber sealing block. This should allow you to extract the element. Once you have done this it will become clear..
Feb 20, 2010 | Washing Machines
Indesit WIA 121 not working - door latch not shutting
At first thought it was door lock mechanism was at fault but proved it to be ok - removed rubber 'boot' which on this model was on two stretchable spring retainers and checked operation of door lock.
Thought door hinges may have been bent so dismantled door, finding the problem to be the pin that the door latch pivots on had come out on one side so not lining up properly. This was easily pushed back into position.
Oct 05, 2009 | Indesit W 123 Front Load Washer
Washing power drawer, the fabric softner section
Pull the drawer out as far as it will come and then grasping it firmly, give it a good tug towards you, this will free the drawer to enable you to thoroughly clean every piece of it, particularly the conditioner parts of it.
Get a piece of wire with a bend on the end, and poke it in to all the holes in the top of the dispenser compartment, this will clera any blockages there.
Plz rate my solution, and feel free to leave any comment.
Thanks.
Jan 09, 2009 | Indesit W 123 Front Load Washer
Indesit wia 121 door lock keeps flashing and when put machine on it goes to a wash without turning dial to correct wash no.
these machines have a memory built into the pcb's which means that if they are switched off or there is a powercut etc they will just carry on from where they were in the cycle as soon as they next power up. if there is a black dot on the timer settings turn the dial to it then switch machine on and this should reset it for you after a few seconds. if this does not work count how many times the doorlock light flashes as this is a fault analysis code they will usually flas then pause for a second then flash again and repeat this sequence until a longer pause (3 seconds) then the sequence starts over.
hope this helps
Jul 28, 2008 | Indesit Washing Machines
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
