Question about HP Color Laserjet Cp2025 Printer Laserjet 600 X 600 Dpi Laser 40000
Cp2025 jam in paper path open rear door - HP Color Laserjet Cp2025 Printer Laserjet 600 X 600 Dpi Laser 40000
SOURCE: Canon MP830 paper jam
Your "Best Solution" posted 10/01/07 needs just a little bit more. I followed the directions and saw the jammed paper but couldn't get hold of it. I then called Canon support and they told me that the green plastic can be pulled up and then the paper under it is accessible. I pulled up the green plastic and was able to grab the jammed paper and pull it out. He also told me that the solution could be found in the Canon knowledgebase with a color picture as well.
Posted on Feb 04, 2008
  • 4 Answers
SOURCE: 202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Posted on Aug 08, 2008
SOURCE: fuser paper jam on Dell mono laser mfp 1125
Please double check if all doors --- including the paper tray cover --- are firmly (repeat FIRMLY !) closed --- seemingly all such are designed as precautionary measures for safety operations.
Posted on May 31, 2009
SOURCE: Cant figure out how to open Tray 1 to clear paper jam
Leave Tray1 closed. Remove tray 2. Push down on green arrows visible after removing Tray 2. You should see the jammed paper on the plastic tray which becomes accessible after pushing down on the green arrows.
Posted on Jul 17, 2009
SOURCE: I'm getting Jam at Reg
Had exactly the same problem... today actually.
Found the solution with another model's manual - I removed the paper from the top, but hadn't realised there was a jam in the paper tray. It was only when pulling it out completely that I found it as below...
Jam at Registration Roller
1. Remove Tray 2 completely.
2. Clear the jammed paper from the printer's
intake slot.
3. Re-insert Tray 2.
4. Open front door A.
5. Remove jammed paper if present.
6. Close front door A
Posted on Nov 25, 2010
I have an HP CP2025 and when it goes to print it says there is a jam in tray 2 but there are no papers stuck, no debris, nothing. It just tries three times to pick up paper and then says there is a jam....
This is called a phantom paper jam and is caused by the printer not being able to grab the paper and feed it into the paper path to print on. There are paper pickup rollers right above the paper tray and when they get worn down they can not grip the paper so they slip. The printer thinks the paper is jammed because it never arrived in the printer. These rollers are user replaceable and come in a kit called RK-CP2025, they are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=318
I hope this helps,
BuddyMc
Mar 28, 2013 | HP Laserjet Cp2025n Printer
Hp cp2025 paper jam message, no paper jammed, even when restarted gives message
try lubricate the paper lefter from down the printer - you must lubricate the two sides
Mar 07, 2012 | HEWLETT-PACKARD HEWLETT PACKARD HP COLOR...
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
I have a HP CP2025 that will not pick up the paper from tray2 or print from tray1. It will pull the paper in from tray1, but it jams at the rear of the printer. It sounds like the printer is trying to pick...
It sounds like a blockage in the paper path at the rear of the unit. This unit picks from the rear of tray 2, and there is a separate path for tray 1 that conveys the paper above that tray and back to where it can intersect the main paper path. Sounds like you have a blockage where those 2 paths intersect.
Remove the cassette 2, and in that hole, there are 2 levers that allow you to lower the bottom half of the tray 1 bypass path. Look back in there for the tiniest scrap of paper left behind.
Next, if nothing is found, open the rear door, and again with a flashlight, look down in the bottom of the paper path for a small bit of torn paper, or some other obstruction. Odds are this is your problem.
Feb 28, 2011 | HP Laserjet Cp2025n Printer
Printer CP2025 error - rear door open. Any suggestions please?
Are you sure that the rear door is not open? There is a door in the rear for jam clearance. Your manual can help you if you can't find this door. Manuals are on line at hp.com if you have lost yours.
Nov 30, 2010 | HP Laserjet Cp2025n Printer
Paper Jam 13.20 on HP 4015
Action:
1. Open top cover and remove toner cartridge. Remove all media in the paper path, and then re-install toner then open and close the top cover.
2. Open read door and pinch blue latches on fuser and pull it out. Inspect the sensor flag for correct movement and any paper obstructions in the fuser rollers. Re-install fuser and Confirm rear door closure.
3. Remove tray 2 and confirm paper is not jammed in the pickup area. Confirm paper size adjusters in the tray are correctly set for paper being used. (Do not set back paper stop to ANY)
4. Replace any defective sensors or flags
Hope this helps. Please keep us updated and remember to rate this answer.
TF
May 24, 2010 | HP LaserJet P4015N Printer
May 05, 2009 | HP laserjet Cp2025dn color Card Printer
Paper jam
MOST HP PRINTERS HAVE A DOOR ON THE BACK SIDE OF THE PRINTER THAT CAN BE OPENED TO REMOVE A PAPER JAM. HAVE YOU TRIED USING THIS TO CLEAN THE PAPER JAM. THERE MIGHT BE SOMETHING STUCK IN THE PAPER PATH THAT IS CAUSING THE JAMS. CHECK THE WHOLE PAPER PATH FROM THIS REAR ACCESS DOOR. OK?
ARCLIGHT1217
Sep 08, 2008 | HP PSC 1110 All-In-One Thermal Printer
Paper jam. we removed the major portion of it. bit of paper is inside. we can't find out that. display shows 13.20.00. we removed front and back except toner catridge. what we have to do.
Try this linke below.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=411171&prodTypeId=18972&prodSeriesId=411171&objectID=c00642524
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Sep 27, 2007 | HP LaserJet 3550 Printer
HP Color Laserjet Cp2025 Printer Laserjet 600 X 600 Dpi Laser 40000 Logo
85 people viewed this question
Ben Johnson
