Question about Bose Audio Players & Recorders
Changing bulb in Bose radio - Bose Audio Players & Recorders
2 Suggested Answers
emissionwiz
  • 76070 Answers
SOURCE: Bose radio light bulb replacement in 2003 Silverado
You have to open up the radio chassis, remove the front circuit panel faceplate (move out of the way)and remove the very tiny 12 light bulbs which are hard wired to the small control panel circuit board behind the radio display. VERY important, use a low temperature soldering pencil and a heat sink in each of the bulbs legs, DO NOT overheat the circuit boards are you will need to replace the radio. You can buy the bulbs from Radio Shack, the part number is 7219 which is a 12 volt 60ma wired terminal base miniature bulb.
Posted on Jul 02, 2012
How do I improve my reception on a Bos Wave Radio with single CD player
The Bose uses its power cord as an antenna. The cord has to be stretched out (not coiled) to pick up stations. It also helps if it's oriented the right way -- try changing the direction (having the cord running east to west, say, instead of north to south). Moving the radio and the power cord closer to a window can help, too, especially in a commercial building. These structures often have a steel frame which can block radio signals. If all the above fail, your best bet is to buy an indoor FM antenna, which can be as simple as a piece of wire made into a dipole antenna or as fancy as one of the Terk mini-towers with built-in amp. Bose sells one for their radio, though it's kind of expensive for a simple length of wire. You can get the same thing from Radio Shack, but if you do, be sure to pick up their adapter (catalog 278-257) to plug it into the non-standard Bose jack. All together you'll spend half what Bose wants. Move it around like you did the power cord and you should see a big improvement.
Aug 05, 2014 | Bose Wave Radio / Cd With Remote model...
Tip
Delco Radio displays and climate control displays remain dark, all GM
Symptom is radio diplay or controls don't light up, Delco CD radio's and Bose preminum sound radio/CD players. Models all GM cars and trucks 1990's to presnt.
This problem is caused by two tiny burnt out bulbs behind the LCD display thay are soldered to the circuit board behind the radio LCD display and can be replaced, this requires the radio be removed and the housing taken off and the front display un-clipped, you will need a low temperature solder pencil and thin strand solder the bulbs are available from Radio Shack, the part number is 272-1092, this is a 2 pack of miniature 12 Volt 60Ma bulbs. This radio display bulb is used in may car models, this bulb also repairs climate control displays as well as other low light displays like switches
on Jan 31, 2010 | Pontiac Grand Am Cars & Trucks
Tip
BOSE RADIO CLOCK/STATION DISPLAY DARK
on Jan 31, 2010 | Chevrolet Corvette Cars & Trucks
Jul 02, 2012 | Cars & Trucks
1998 chevrolet silverado delco radio backlight bulbs are not working. Removed faceplate for radio, which exposed a circuit board. Looks like this board will have to be removed to access bulbs. Has anyone...
The tiny light bulbs are indeed soldered to the front circuit board and a pain to replace. The bulbs can be had at Radio Shack, part # 7219 I did the ones in my Delco/Bose Gold radio in my Corvette, took all afternoon.
Feb 02, 2012 | Ac Delco AM-FM Radio Cassette
Bose Wave Radio/CD clock running very slow. Now that I've moved it across the pacific ocean(US to NZ) the clock is suddenly running very slow, losing 10-15 minutes per hour while running on any...
My guess is that the clock in the radio is based off of the AC line frequency (not voltage). In the US the line frequency is 60hz (hertz). I'm guessing that the line frequency in NZ is 50hz, which would seem to explain that extreme amount of time loss. I would check with Bose, but I'm betting they make different 50hz models for export.
May 16, 2010 | Bose Wave Radio
The RSX BOSE radio stopped working.
If you disconnect the bose radio, it loses it's programing.. Needs to be taken to a GM dealer and vin coded. as for the volume knob, it's digital.. if it's not working it wont be a connection issue, it's likely a flaw on the board. The best place to get that fixed is United radio in NY. 1-800-448-0944
Aug 07, 2009 | Bose Car Audio & Video
Bulb replacement on 2004 Chev Silverado Radio
No it cannot but if you go on ebay im sure you can find a cheap replacement.
Mar 13, 2009 | 2000 Chevrolet Silverado
120v Bose Wave Radio/CD player plugged into 240V outlet
there is a fuse inside but after changing the fuse if it still dont work the rectifier could be bad.
Jan 13, 2009 | Bose Wave Radio
Bose wave music system
Check remote and replace its batteries.
Does this remote work on any other device?
Sep 16, 2008 | Bose Wave Radio
59 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
