Question about Moultrie Cameras
Moultrie taril cam shows locked card 1. Yes the card is unlocked and works fine in same model camera. 2. Yes I've cleaned the contacts. 3. shows locked in all modes plot, vid, ect
SOURCE: sd locking
I had this problem also. To solve the problem I blew into the slot where the card goes and it then read the card. If dirt gets into the port it causes the sd card to lock. You may have to use a pressurized can of eletronic spray to clean the port.
It worked for me.
Posted on Mar 04, 2009
SOURCE: moultrie camera locked up.
THROW IT IN THE TRASH! NO MORE PROBLEM.
Posted on May 04, 2009
t00nz
  • 4738 Answers
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Posted on Oct 19, 2009
SOURCE: our lumix dmc-fs3 camera says the memory card is
It should have a little switch on the side. You slide it down to lock, up to unlock.
Posted on Feb 12, 2010
  • 296 Answers
SOURCE: I have (2) DGS-200 Moultrie cameras that the LCD
WWW.MOULTRIEFEEDERS.COM WILL SEND REPLACEMENTS AND INSTRUCTIONS FOR FREE....
Posted on Feb 17, 2010
My moultrie says "motion card lock" even when I have the SD card unlocked and also when I have tried other SD cards. What is wrong with my camera?
The most common cause of this is the contacts inside the camera in the card slot are dirty. You can blow the card slot out with compressed air and you can also clean the contacts on the card with a q-tip and alcohol OR a pencil eraser. Then try again.
Sep 12, 2015 | Moultrie Cameras
My moultrie camera M-80 tells me my trail card is on lock and wont record pictures
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 02, 2013 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have a moultrie cam viewer. It views pics off sd cards for my moultrie game cams. (I have 2 cams both with 16g sd cards in them m-80 xt, m-80 blk) it has worked fine for about 7 months. But now it just...
Try the cards in another camera. If you get good images to show, then the problem is in the cameras. If not, then the problem is in the reader. See whether some dirt is in the slot interfering with the contacts.
Oct 19, 2013 | Cameras
Moultrie game camera
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 09, 2013 | Cameras
Shows card lock
Jan 24, 2013 | Moultrie D55 Digital Camera
Moultrie D-55irxt says sd card locked on
Dec 03, 2012 | Moultrie MFH-DGS-200 Digital Camera
I have a Moultrie game spy D- 40.It shows card lock on the LCD and will not operate.What ,s up?
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 05, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie MFH-DGS-200 .... says SD Card Locked on
ck postion of switch on side of SD card...should be pushed toward contacts
Oct 23, 2009 | Moultrie MFH-DGS-200 Digital Camera
Moultrie DGW-100 won't read sd card
check small switch on side of SD card; should be pushed toward contacts.Using the USB cable provided with cam, PC SHOULD RECOGNIZE DEVICE...might have to go thru windows explorer to find it, then use windows media player, or other, to open.
You are running 98 or later, right?
Apr 11, 2009 | Moultrie MFH-DGS-100 Digital Camera
Cameras Logo
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
