Question about Hardware & Accessories
I can't find a manual on how to set the tm416 timer
Nomamodle1507 set timer
Copy following links to identify timer and read instructions or download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
http://waterheatertimer.org/How-to-set-timers.html
Add a comment and describe timer or product in detail.
Jun 01, 2013 | Intermatic Hardware & Accessories
Like to set digital timer.It's a Provalue TS-EA1
1) Copy following links for possible TS-EA1 timer manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
http://waterheatertimer.org/pdf/TS-EA1-digital-timer-manual.pdf
2) This is a new series of 50 Hz timers made for worldwide 230Volt market.
Manual was written based on other similar timers, and how those timer buttons worked, although there is not another timer with 1:1 same buttons.
3) Add comment and say what you discover when trying to program your timer. Then possible manual can change accordingly.
Jan 06, 2013 | Hardware & Accessories
How to set tork outdoor timer model no.sa0022
Timer is not identified.
1) Copy following links to help identify SA0022 timer:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
2) Add comment and describe timer in exact detail so expert can possibly identify same-similar manual
Dec 02, 2012 | Hardware & Accessories
HOW TO SET TIME AND DAYS SWITCHES
Copy following link for instructions setting analog timers:
CU750 appears to be Mr Steam with 30 minute digital timer, or 30 minute spring-wound mechanical timer.
Copy links following links to download Instruction manuals for these timers:
CU 99216DIG timer manual:
http://waterheatertimer.org/pdf/Diehl-652-Operating-micro-II.pdf
CU 99216B timer manual:
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Apr 22, 2012 | Hardware & Accessories
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
HOW DO i SET THE WOODS 59203 TIMER LOST DIRECTIONS
Woods timers and manuals:
The picture shown at fixya for 59203 is not correct.
Picture shows 49112 which is also TD1000:
Manual for 49112-TD1000:
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
Manual for 59203:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Manual shows 15 steps.
Plug timer in to charge battery. If battery will not charge, then timer is bad.
Set current time.
Set program1 ON time.
Set program1 OFF time
Set program2 ON time
Set program2 OFF time up to 20 pairs of ON-OFF times.
When programming is complete, press ON/OFF/Auto until Auto shows in display.
Add a comment of you need help with specific programming.
Nov 28, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Hardware & Accessories Logo
44 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
