Question about Toshiba Computers & Internet
My toshiba laptop have power jack pluged in light but refuse to turn on at all ( dead)....what should I do or what are the steps to solve the problem
    Top Expert:
  • Toshiba Master
  • 21,522 Answers
The most likely cause, if Nvidea GPU is an overheated GPU causing the system to hang. Replace the GPU.
Posted on Dec 06, 2016
IB4G2008
  • 3587 Answers
SOURCE: power
ok..remove battery..try it on ac alone..
Posted on Feb 19, 2008
SOURCE: Steps to replace DC power jack L15-S104
same problenmm!!
Posted on Oct 15, 2008
joecoolvette
  • 5660 Answers
SOURCE: dead short on power jack
Should be battery first, Then AC adapter (Charger)
Dead short on DC Power Jack?
Are you aware of how a DC Power Jack is made, (Component structure), and how it attaches to the motherboard?
If not, allow me to explain. This is an example of an average DC Power Jack,
http://us.st12.yimg.com/us.st.yimg.com/I/yhst-42877593004970_2046_1336946
The outside housing of the DC Power Jack, is barely larger than the outside of the AC adapter (Charger) plug.
It's about a 1/4 inch wide, 3/8 inch inch tall, and 1/2 inch long.
The body is made of plastic.
The outside shell opening in the body is the Negative contact.
The pin in the center is the Positive contact.
Those flat metal prongs, or pins, you see in the photo, go down through the motherboard, are are soldered on the bottom side.
The photo of the jack is upside down, in relation to how the jack sits on the motherboard.
When the 'Charger' plug is plugged into the power jack, it can get bumped. A hard enough bump, or repetitious bumps can damage
the center pin mounting, break the outside metal shell loose, and/or break the plastic housing.
It can also break the solder joint/s for those flat metal pins.
AC adapter unplugged from the laptop, battery removed, see if you can take a pencil eraser, and move that middle pin around. You may see the entire jack move.
There is also a large number of laptops, made with a defective motherboard design. To explain, I'll have to give you a crude example.
Think of the laptop motherboard as being a 1 foot square. (It isn't. It's irregular shaped)
Now along the edge of the 1 foot square, attach a 2 inch square.
It's actually all one piece.
Due to accidental bumping of the 'Charger' plug while in the power jack, this 2 inch 'Peninsula' can break away from the main body of the motherboard. (1 foot square)
There are circuit traces on the motherboard. (Think of a circuit trace, as a Very, Flat, Thin, copper wire)
These circuit trace can become stretched by the cracking, or breaking away of the 2 inch 'Peninsula'. They can then be exposed to circuit traces they're not designed to touch. This can cause a direct short.
(Also, due to the bad design of these motherboards, the laptop user can be just using the 'Charger', in an everyday situation, and this 2 inch 'Peninsula' can break.
Just by plugging in, and unplugging)
Posted on Apr 23, 2009
dasaradh
  • 66 Answers
SOURCE: Toshiba Laptop wont power on
install windows again
Posted on Aug 01, 2009
  • 29 Answers
SOURCE: how to replace power jack on a105-4094 laptop
It is not easy. If it uses the standard round connector you need to find a replacement one (Radio Shack had the one I replaced) Then de solder the old one then solder the new one. This takes special tools you can also get at Radio Shack but if the connector is too close to small components then you will need a soldering iron with a variable heat option. Sorry long way to say.
Yes you can, on a skill-set from 1 to 10 this is about an 8
You will spend $70 (Retail) in tools for a fix the manufacturer will charge you $80 + Shipping for. Plus the manufacturer is less likely to leave you with a cold solder joint and melted plastic.
Sorry about the bad news.
Hope this was useful
Posted on Sep 14, 2009
Will not turn on
power issue on board or bad memory check to see if you have any lights when plugged in and does the laptop make any sounds like it booting up when turned on or is it totally dead if dead check power supply if that's good you have a bad power linked to board if that's the case go to best buy.com in clearance theres great laptops there for 319.99
Mar 01, 2013 | Toshiba Computers & Internet
Toshiba c655d-s5133 plugged in not charging
Dead battery? Try another cord/charger with the EXACT same power specs.
Jan 25, 2013 | Toshiba Satellite Computers & Internet
Won't turn power on
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Toshiba Satellite L555 AC Adapter 90Watt 19V 4.74A
Jan 05, 2013 | Lifetime Toshiba Satellite L555S7008...
Connecting charger and letting charge for sometime...charging light doesnt turn on and laptop doesnt turn on...any advise?
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-65w.html
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-3-95a.html
Nov 07, 2012 | Toshiba Satellite C655-s5140 Laptop
My battery light is off.
The battery might be dead. Batteries only have a useful life and after that they have to be replaced.
Does your laptop work ok off the AC Adapter Power Cord? If so, your battery is dead and your power cord is good. If the laptop does not work off the Power Cord then either your Power Cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. In either case a good battery will not charge if the power cord or the DC Jack is bad.
Check your DC Power Jack which is where the power cord plugs into the compute. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Toshiba Satellite A105 Notebook
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
Toshiba Satellite a105-s4014 wont turn on
Dead could be a shorted MOSFET in the CPU line which is common for the age. Need to verify Voltage at Jack and the I/O's the BIOS chip..
Feb 02, 2008 | Toshiba Satellite A105-S4014 Notebook PC
Computers & Internet Logo
29 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
