Question about Planet Audio Car Audio & Video
What is the displacement of a planet audio big bang 2 15" D sub ?
4 Suggested Answers
sicaudio
  • 96 Answers
SOURCE: problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Posted on Jan 10, 2009
pctech1
  • 1940 Answers
SOURCE: MY AMP TURNS ON BUT NO AUDIO OUTPUT TO MY SUBS! I
First, test your sub terminals for an Open connection, or no resistance. This is to test if your sub is blown. This is usually the case.
Double check your wiring, not only to the sub, but from your headunit to your sub. Make sure your headunit is configured to work with your amp, if you have a setting for this (for instance, SUB: ON).
Posted on Jul 14, 2010
Suzman
  • 642 Answers
SOURCE: need to wire my planet audio big bang 1200 watt
N/C - No Connection
Posted on Dec 04, 2010
I have a planet audio rdx 1000. I don't use it
I think maybe you pushed the subs too hard and the amp shut down in a way that will require repair
Apr 08, 2013 | Car Audio & Video
I just did an update for little big planet and now i dont have any audio for this game. can this be fixed?
Do you have HD audio selected on your ps3 on a non-HDTV? If so, change the settings to Standard Def.
Jan 07, 2011 | Sony Little Big Planet
MY AMP TURNS ON BUT NO AUDIO OUTPUT TO MY SUBS! I HAVE A PLANET AUDIO AMP 1900 WATTS MONO.
Jul 14, 2010 | Planet Audio AP3000D Car Amp
Trying to put ported reccomended subs in sealed box.
Well, 1.6 cubic foot for a 15 is not nearly enough. A ported box for 1 15 should be in atleast 3 cubes by itself. I suggest building a new box yourself or getting someone else to do it for you. If factory specs on those subs is no larger than 3 cubes per sub then I'd get the box built to 3 cubes per sub after all displacement and tune it in the upper 30's range. Putting big subs like that in a small sealed enclosure can and will damage a sub. and if you try to port an enclosure that is too small to begin with that will also hurt the woofer. Do it right or learn the hard way.
May 26, 2010 | Kole audio KMX-15 Car Subwoofer
How should i wire my sub
if your amp has a bridge do nt bridge the subs just connect them normal planet audio subs usually dont have a high potential to withstand too much watts even if the subs say 1200 watts thats not true nwatts check the box the subs came in it will tell u true wattage it may say rms
May 24, 2010 | Nitro BMW-481 Car Audio Amplifier
I have a Planet Audio Big Bang 3000 Watt 1 ohm stable amp I was wondering if i could run 2 HIFONICS OLYMPUS 15's they are 2,400 Watts rms each 4,800 max each so would i overload my amp and im putting it in...
that should be fine, but with that much power you might want to invest in earplugs, the SPL or sound pressure level from those speakers could rip your ear drums out of your head, kick them around for awhile, spit on them and shove them back in through your nose.
**Disclaimer, I am not a medical doctor and do not claim to be, I am simply warning you about hearing loss as I have suffered from between 30 - 50% hearing loss because of loud bass. but seriously, if the speakers sound like """" turn it down a little bit. that system should work fine though.
Mar 03, 2010 | Car Audio & Video
I am wondering about car amplifiers, I don't know what kind to get, I have Alpine 6.5" 2-Way Car Speakers (SPS-600), 80 watt as my front speakers, and Alpine 6 1/2" 2-Way Car Speakers (SPR-17C), 100 watt...
I would strongly recommend that you get a 5 channel amp that puts out 75watts rms per channel that will deliver between 200-300 watts to the sub channel. I use planet audio amps myself and they run strong all day every day-maybe you could look at a planet audio vrx 600.5(5-channel) it throws 100w x4 and 200 or 300 to the subs depending on the resistance of the sub. Good luck
Jan 27, 2010 | Car Audio & Video
Problem when hooking two 12 inch subs to one amp
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Planet audio vx3002
Sorry wayne2953 but this amplifier isn't stable @ 1ohm loads. This amplifier would be better suited running a pair of 12's, 4 12" subs could run if configured correctly but the subs would be underpowered and probably not sound very good.
Features of Planet Audio VX3002:
  • Max Power (2 Ohms) : 300W x 2
  • RMS Power (4 Ohms) : 150W x 2
  • Bridged Power (4 Ohms) : 600W x 1
  • Signal-to-Noise Ratio : 102dB
  • Frequency Response : 20Hz-20kHz
  • Dimensions : 10-5/8"W x 2-7/16"H x 16"L
Mar 31, 2008 | Planet Audio VX3002 Car Audio Amplifier
Car Audio & Video Logo
52 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
