Question about Seagate Barracuda 7200.9 (ST3250824A) 250 GB Hard Drive
I transfer my hd to an external case and now doesnt reconigze it
  • 3 Answers
If you transferred you C: drive, the computer won't boot. if not, then you might have the pin setting on the drive set as a slave. you need to set it to master. on the end where you plugged in the power and data cable, their should be a small jumper. check either on the sticker or on the plastic around the jumper. move the jumper to the appropriate spot then plug the enclosure into the computer and the wall if it needs power.
hope this helps.
Posted on Jul 20, 2009
What is the difference between a external hard
External hard drives contain a power supply to operate a standard hard drive in a case. It usually connects to a USB port. Usb drives get their power from the wire that connects it to the USB port A regular internal hard drive gets it's power from the computer's power supply wiring. The data cable is either a flat ribbon cable or a 6 pin cable that connects directly to the mother board.
Oct 15, 2014 | Computers & Internet
I am trying to transfer all my photos from my old freecom external HD to a new external HD, but the Freecom keeps switching itself off mid transfer, every few minutes. I'm worried I'm going to
sounds like a faulty drive, afraid without sending it off only way you will be able to get info off is by transfering it bit by bit,
best u use cut files at least u dont have to keep copying same files over and over that way
Jun 16, 2012 | Freecom Computers & Internet
I have unplugged my maxtor 300gb external hard drive from one pc and have plugged into my laptop to transfer data. Light goes on but doesnt seem to be showing up on laptop 'My Comp'
you might want to try to unplug to HD's power and plug it back in then plu the USB into you computer....make sure that you remove the usb safely and not just unplug it.
Nov 24, 2010 | Maxtor OneTouch II external hard drive...
Same problem
please remove the casing of the external drive and connect the drive to your pc .(without interphase) it will get detected as a raw hard disk hdd regenerator will then detect this easily . if it doesnt it would give you a answer that no drive has been found on the int port.
Sep 19, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
Cannot transfer files that are greater than 4GB
The lack of free space iis on your internal HD not the external. Whenever transferring files from one drive to another, you are acturally making a copy of the file to be transferred and sending the copy to the new drive. If your internal HD is nearly full, you can try to Cut and Paste the files to the external, or clear up more space on your internal b/4 tryiing to move the bigger files. Best of luck.
Greg
Jul 09, 2009 | Western Digital 500GB My Book World...
Dell Inspiron 1525 - Firewire not working
It may be the communication setup.
You might need to set within the Camera PTP protocol.
The WD drive specs out a 6 pin connector, not a 4 pin.
Nov 17, 2008 | Computers & Internet
Windows xp to vista external HD transfer problem?
It is exactly right... YOU are not 'in control' of the hard drive and your buddy's computer doesnt have the 'permissions' to work with YOUR files...
It MAY be possible to get the okay if he logs into his computer as the administrator.... it is NOT an actual 'hardware' issue... being able to see the files says that... XP and vista are 'close enuf' design-wise that drive compatability isnt it either...
If your friend can log in as 'administrator' he will likely be able to take 'ownership' of the files on your 'external' drive and get what you need!
Aug 18, 2008 | Dynex DX-EF101 (DXEF101) External Floppy...
Open up the case
Well, since you are discarding the case, use a small flat head screw driver or something to pry the case open. Once inside, the HD will be plugged in to a circuit board and screwed in place. Unscrew it and carefuly unplug the HD from the circuit board. Then you can transfer it to another external HD housing.
Jun 19, 2008 | Maxtor OneTouch III Mini Edition (R01E100)...
Help retrieving files from simpletech 320gb hard drive!
I have to admit I haven't used a Mac since high-school, but I can tell you that my first thought on this problem was "file system".
Most external HD's are formatted to be used on a Windows PC, and many are even formatted as NTFS. If this is the case, last I heard anyways, Mac OS doesn't support NTFS.
My suggestion is to use either machine to format the external HD (**you will lose all data on it**) as a neutral file system. By that I mean one which will work on both operating systems.
I could be wrong about this, and Mac OS may support NTFS, but if that's the case somone will be kind enough to correct me.
Mar 15, 2008 | Computers & Internet
Seagate Barracuda 7200.9 (ST3250824A) 250 GB Hard Drive Logo
163 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
