Question about Dishwashers
Model: PFS22S1Sbss with French doors.
The door closing latch is broken. Can it be fixed without replacing the entire door?
  • 82 Answers
SOURCE: maytag quiet series 300 - model MDBH970AWW door
remove the inner door panel and control cover, switch will pop out after that
Posted on Jul 17, 2009
  • 136 Answers
SOURCE: late model saturn; broken door latch, how can you open the door?
simply go through your fold down seats threw the trunk provided you cant get in from passenger door.
Posted on Dec 07, 2009
  • 3074 Answers
SOURCE: door latch is broken. Door
you can purchase a door latch:
Repair Clinic:
http://www.repairclinic.com/Bosch-Dryer-Latch-Parts
eBay:
http://shop.ebay.com/i.html?_nkw=+dryer+door+latch&_sacat=0&_odkw=bosch+dryer+door+latch&_osacat=0&_trksid=p3286.c0.m270.l1313
Posted on Jan 10, 2011
  • 118 Answers
SOURCE: Door latch appears broken and
If the tongue on the door is OK and moves under spring tension then you will need a time delay door lock If it is only the latch then you could have a go. It can be awkward to fit the spring around the tongue. Have a good look at it first when you get the door apart to make sure you can see how it fits. Good luck. If we don't try then we would never do any thing would we. But we have to know our limitations Tony www.appliances.cjb.net
Posted on Mar 03, 2011
Sea Breeze
  • 4655 Answers
SOURCE: ge pfs22mi door gasket
This is going to be tricky so watch the video and tell me if the answer to you question comes out and resolved by the tricks revealed in the below video.. Sea Breeze
When you say latch can you tell me the part number of the latch you say that you need replaced? Here is a link to the parts you are describing HERE
GE Profile French door bottom freezer Model # PFS22MISBWW Door Gasket and related parts
Posted on Apr 02, 2013
I have a 2002 Acura MDX and the latch is jammed or broken and the door will not click shut because the latch will not catch. Is there a way to fix it without replacing the mechanism?
Which door? Will the door close and not latch or will the door not quite close and bangs as you try to close it. Have a look inside the latch to see if the latch is in the locked position. If it is, pull on the door handel and use your finger to release the latch into the open position. If latch is in the open position, check the striker attached to the door jamb to make sure the screws have not come loose and allowing the striker to move causing the door to not properly close
Aug 22, 2015 | Acura Cars & Trucks
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Ge pfs22mi door gasket
Apr 01, 2013 | GE Profile Bottom-Freezer Refrigerator...
Plastic latch on left french door broken
Go to www.partselect.com put your model number in, click on the diagram. For the door. Should be part #PS1016086
/uploads/images/9_1_2014_3_03_11_am.png
Jan 30, 2011 | GE Profile PFS22SBSS Bottom Freezer French...
Latch Hooks Not Working
This is a VERY common problem, and the fix can sometimes involve replacing the door.
The following site should have the latch/gasket assembly: http://www.repairclinic.com
AFAIK, the top latch can only be replaced with the entire door gasket assembly, but it's not too difficult to do.
A google search on 'GE refrigerator latch' will find you thousands of other (former) GE customers who have had this problem.
Oct 23, 2009 | Refrigerators
Our French Door model after almost 2 yrs pops open the one door after closing the other, and it doesn't set off the door alarm because it doesn't pop it open far enough to trigger the alarm. This causes...
We solved this problem by replacing the plastic parts on the top & bottom of the door that 'latch' the door closed.
On the top of each door is a white plastic 'cam' that latches into a receiver at the center point of the refrigerator chamber. One of mine was broken.
Additionally, on the bottom edge of each door is a white plastic hook-shaped 'stopper' that provides spring tension. I replaced both of those and now all is happy.
Got the parts from RepairClinic.com
Item #: 1266811
Description: Door hinge cam (left)
Price: $2.40
Item #: 1266810
Description: Door hinge cam (right)
Price: $2.40
Item #: 1267543
Description: Stopper,door
Price: $2.40
Aug 16, 2009 | LG LRFD25850 French Door Refrigerator
Dishwashers Logo
Top Dishwashers Experts
