What is the code for a Goldstar ec480cm VCR? I'm using a Direct TV remote to program the code.
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
0204,0201,0229,0227. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" of your device; that you want set-up code, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 06, 2016
I have a all for one remete urc#4063b06 need code for samusung tv/vcr modelcxa192680b
There is no code for Samsung TV/VCR combo units. Try the Samsung VCR codes: 240, 045 and the Samsung TV code: 060, 427, 056, 030, 019, 178 . Program the VCR and the TV buttons separately.
Most One for All universal remote manuals and code lists are available from: http://www.oneforall.com/support/manual . You may need to change the country listed at the top of the page. Then use the drop down menus to select Universal Remote and the model. The direct link to the manual for the URC4063 is http://www.oneforall.com/uploads/support/00b313f46269f3fc78988edae4518f03.pdf .
Please note that the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your TV/VCR is newer than your remote, you may need a new remote.
I hope this helps.
Oct 03, 2011 | One For All URC-3021 Remote Control
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
I need a code for RCA remote RCR311STR for a Durabrand television model BH2004D.
In order for the 4 component universal remote to control your TV, you must program it with the TV code that matches your TV. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the TV.
  2. Locate the enclosed TV Code List. Find your brand of TV.
  3. Press and hold the CODE SEARCH key until the indicator light illuminates. Then release the CODE SEARCH key.
  4. Press and release the TV key. The indicator light blinks and then remains lit.
  5. Use the number keys to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your TV and press the ON•OFF key. If your TV turns off, you have found the correct code.
  7. Write the code down for future reference.
  8. If your TV doesn't turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
Program for VCR: In order for the 4 component universal remote to control your VCR, you must program it with the code that matches your VCR. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the VCR.
  2. Locate the enclosed VCR Code List. Find your brand in the VCR Codes.
  4. Press and release the VCR key. The indicator light blinks and then remains lit.
  5. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your VCR. Press the ON•OFF key. If your VCR turns off, you have found the correct code.
  8. If your VCR does not turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
May 11, 2011 | RCA RCR311B Remote Control
RCA RCR412b remote
Direct Code Entry
To program your universal remote to control your components using the
Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you
want the remote to control (TV, VCR,
DVD, satellite receiver or cable box).
2. Locate the enclosed Code Lists. Find the
list for the component you wish to
program. Find your component’s brand.
You will see a listing of four-digit codes
for each brand. If your brand isn’t listed,
program the remote control. (Refer to
pages 7-8 for Manual and Auto Code
Search methods.)
3. Press and hold the component key (TV,
DVD, VCR·AUX, SAT·CBL) you wish to
program. (To program the VCR·AUX key
to control a component other than a VCR,
see page 7.) The illuminated ON·OFF key
turns on and remains on. If you release
the component key any time during the
Direct Code Entry procedure, the
illuminated ON·OFF key blinks four
times, and the process is exited. The last
programmed code under the component
key is retained. Toshiba codes:2011, 2029, 2030, 2033, 2093, 2107, 2110, 2111, 2112
Sep 13, 2009 | Televison & Video
Remote codes
Hope this helps.
Len
Feb 27, 2009 | Televison & Video
Remote codes
Contact Direct tv and they should have the codes to program the remote tothat tv. Or contact Universal remote @ 919-573-7854 919-573-7854
Aug 17, 2008 | Philips Magnavox Learning Universal Remote
Oneforall remote urc-3021B00
i need the instruction for my OneForAll Remote URC3021B00 i have all the codes needed for any tvs
Jun 28, 2008 | Televison & Video
RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
These are all of the codes I have for the RCA universal remote.
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 24, 2008 | RCA Universal Remote Control
RCA REMOTE CODE
Jun 22, 2008 | RCA Universal Remote Control
Sitting in a cheap hotel room after work and have to get up to change the channel, have a Philips universal cl034 remote but do not know how to program it to the older Hitachi tv.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Here is the link for your remote.
Here is the list.........
Save Code list for future reference Refer to the setup procedure below and look up the 3 digit code for your brand of TV, VCR, etc., from the list below.
Refer to the Owner’s Manual for your remote for more information.
TV including LCD,
Plasma, & Panel TVs
HITACHI ........... 0410 0507 0815 0607
....... 0808 0002 0502 0710 0701 0802
....... 0707 0315 0515 0715 0519 0324
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing “0” performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds.
Code Search (by Device)
If after trying “Direct Code Entry” or
“Code Search (by Brand)” your device
does not respond, or if your brand is not
listed, try doing a device search of the
code library for your code by following
the steps below.
1. Manually turn on the device (TV,
VCR, etc.) to be controlled.
button.
4. Press the CHANNEL UP button
repeatedly (up to 300 times) until
the device to be controlled changes
channel. The red indicator blinks,
then stays lit.
5. Press and release MUTE to install
the code.
Most users will want to store VCR
codes under the VCR button, Cable
codes under Cable, etc. If you want to
store a VCR code under Cable, etc., first
follow the procedure for Direct Code
Entry and press Cable in step 2 of
Direct Code Entry, then enter ANY
VCR code in step 3 of Direct Code
Entry. Then follow the steps above for
Brand Search or Complete Search.
Brand Search Table
Look up your brand in the appropriate
column (TV, VCR, etc.) in the table
below. Look for the digit (1, 2, 3, etc.)
that applies to your brand, and enter it
in step 4 of “Code Search (by Brand).”
Digit
6
78
90
TV
RCA, GE,
Proscan
Zenith
Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Daewoo
Hitachi, Sanyo,
LG-Goldstar,
Samsung, JVC,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson
N/A
N/A
N/A
ALL
VCR/DVD/DVR
RCA, GE,
Proscan
Zenith, Apex
Marantz, Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Daewoo, Yamaha,
Denon
Hitachi, Sanyo,
LG-Goldstar,
Samsung, JVC,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson
N/A
N/A
N/A
ALL
CABLE
Scientific Atlanta
Jerrold
Tocom, General
Instrument,
RCA, GE,
Proscan, Pioneer
Zenith, Gemini
Philips,
Magnavox
N/A
N/A
N/A
ALL
SAT/DBS
RCA, GE,
Proscan, Pioneer
Zenith, Gemini
Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Hitachi, JVC,
Samsung
General Instrument,
Echostar, Dish,
Hughes, Primestar
N/A
N/A
N/A
ALL
CD/AUDIO
RCA, GE, Proscan
Zenith
Marantz, Philips,
Magnavox
Sony, Panasonic,
Technics, Sharp,
Toshiba
Hitachi, Sanyo,
JVC, LG-Goldstar,
Samsung,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson, Optimus
Pioneer, Teac, Nad
Kenwood, Yamaha,
Denon, Onkyo
N/A
ALL
HDTV Set Top Boxes
HITACHI . 0538 0324 0336 0931 0834
Mar 04, 2008 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
