Question about Frigidaire Washing Machines
We have a frigidaire flcd07ggcwt. Today we tried to use it but it is not working. The lights come on but when we try to start the machine, nothing happens. Can u please suggest something. Thanks Dan
SOURCE: Frigidaire GLTF2940ES
Is it draining completely?
Posted on Feb 07, 2008
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
SOURCE: My Frigidaire front load washer won't start
A year later! I experienced the same problem this morning - exactly as you, Bessie24, stated. I could hear a faint humming sound and thought the lock mechanism was still trying to complete its locking function. It would know the lock function was completed when the lock trips the wee (micro) switch. I reckoned if the female portion (with switch) were a tiny bit loose, the switch might not trip, so I loosened then tightened the two screws attaching it to the carcass of the washer (as opposed to the door part) while pushing upward on the same part. This fixed my problem and i hope many others find this procedure useful.
Posted on Oct 11, 2009
  • 713 Answers
SOURCE: The lights come on, but the machine doesn't start
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
Posted on May 06, 2010
livewire874
  • 618 Answers
SOURCE: My whirlpool LHW0050PQ4 worked fine last week, but
Do you hear the door locking and unlocking?
Posted on Nov 22, 2010
Frigidaire flcd07ggcwt catalog
go to www.fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 19, 2012 | Frigidaire Washing Machines
I have a frigidaire washer, model ftf2140es3. It ...
try pressing select and option button at the same time. We had all the lights lit up but it would not start or cancel until we did that. or slam the door,,
May 16, 2010 | Washing Machines
Frigidaire FWX233RES4 washing machine won't work
Sounds like there's something such as a small sock that has gotten sucked into the pump. This will keep the pump from spinning, cause extra noise, and the belts may appear fine but it may be stretched... if you're willing to deal with a little disassembly, unhooking hoses, spilling some water, you can probably handle this.... Good luck and let me know if you need any more assistance..
K
May 10, 2009 | Washing Machines
When i run the machine the breaker keeps going out. i tryed pluging it in deferent wall plug but same thing happenes. its been working fine till today.
Assuming there isn't a conflicting electrical load on the same circuit, there could either be a short somewhere in your washing machine or a problem with the washing machine transmission and/or motor. Since you already tried a different outlet (good move), it sounds like the washer itself. Try running the spin cycle alone with nothing in the washer and see what happens. It could just be the washer was overloaded at the time.
Apr 07, 2009 | Frigidaire Washing Machines
the humming noise is problably the drain pump, which problably has something (sock or such) blocking it, by removingthe fornt panel youlll be able to acess t hdrain pump assy, to check for a blocklage,,( UNPLUG UNIT LIVE WIRES!!!)
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front loading frigidare washing machine
Check breaker only one breaker are function recock it the two breaker try to start it .
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
