Question about Nespresso Coffee Makers & Espresso Machines
Installed my Nespresso D300, turned it on, everything seems to be ok, until I press the coffEe button and the water comes down from the bottom of the machine, and cold...
    Habit-Forming:
    New Friend:
  • 154 Answers
You have to open foult pipe or plastic broken need replacing
Posted on Dec 11, 2016
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
How do i clear the air bubble in the nespresso machine?
OK fill the tank and only use water press the small cap botton and after 5 seconds stop the machein and do the same again untill the pump gets the water into the system
Sep 17, 2014 | Krups Nespresso Essenza XN 2009 Espresso...
Nespresso d300 appears tap close and does not brew
It probably need descaling. However, if no water comes out at all, descaling is a bit hard. You may need to take out the pump and dip it in vinegar or another descaling fluid.
May 19, 2014 | Nespresso D300 Espresso Machine
Magimix M190 CITZ
Are you using genuine nespresso capsules? Are they seating properly. Open the slot where you put the capsule in and check its very clean and nothing is stuck in there.
Have you tried resetting to factory settings?
Apr 03, 2014 | Nespresso D300 Espresso Machine
My Nespresso citiz lungo button will only give expresso amount of water
Ok, what you have done is programmed your machine. If you hold down the button for 3 secs you get 3 secs of coffee, so turn on your machine wait for it to warm up then without using a capsule press and hold the button until you get 110mls for a lungo and this will be stored in the memory. If this doesn't work there is a on/off switch on the right handside turn it on with your finger down on the lungo button for 5 secs and then release the button and this will take it back to factory settings.
Jan 13, 2011 | Nespresso Citiz D110
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Nespresso C1OOB not sucking water out of the tank anymore
I had the same issue and spoke to Nespresso this morning.  To solve this you need to reprogram-put a capsule in the slot and place a cup on the drip tray-press and hold the lungo button until the coffee has reached the desired height in the cup and then release the button.  That should work and every time you make a lungo cup it should be that amount. Hope this was helpful.
Oct 19, 2008 | Nespresso C100B Essenza Single-Serve...
It flashes READY SCALED
i found out that the button that warms up the steamer also has another function. if you start with the machine completely shut off but still plugged in, and press and hold the steam button, it gives you instructions for descaling and walks you through the process, telling you what to do at each step until you are done. so i did it and just finished a few minutes ago.
Aug 04, 2008 | Nespresso D300 Espresso Machine
Nespresso magimix M300
Sounds like it is deffective.  If it's under warranty (under 1 year old) Nespresso will pick it up at your residence and fix it/replace it for fre.
Aug 16, 2007 | Nespresso D300 Espresso Machine
Coffee Makers & Espresso Machines Logo
49 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
