Question about Hardware & Accessories
Programming I have lost the user guide and do not know how to set the timer
    Top Expert:
  • 51,587 Answers
Search Google
Posted on Dec 06, 2016
Westek timer manual
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Westek TMDW10 is same as Utilitec/ probably made by Intermatic.
Gene
h
Jan 26, 2014 | Hardware & Accessories
User's guide for kambrook electronic timer kd94
Could not find a free guide, but e-how lists the basic instructions.
Instructions
    • 1 Set the day and time on the timer. Press and hold "Clock." While holding the "Clock" button, press "Day" to scroll through the days of the week and select the correct one. Press the "Hours" and "Min" buttons to select the correct time. Release "Clock" when you are finished.
    • 2 Press "Prog" set the "On" time for the switch. The word "On" and the number "1" will appear on the left side of the display.
    • 3 Press "Day" to choose an individual day or a block of days. Choosing an individual day means that this specific program will only activate on that day; choosing a block of days means that the program will be active on each day in the chosen block.
    • 4 Set the time that you want the timer to switch on by using the "Hours" and "Min" buttons to select the appropriate time. Press "Prog" when you are done to complete your entry of the "On" time.
    • 5 Select the "Off" time for your timer by using the "Day," "Hours" and "Min" buttons to choose when you want the timer to switch off. Press "Prog" again to save this entry. Repeat steps two through six to set additional timers.
    • 6 Press "Day" and "Hours" to activate the random timer mode. An "R" will appear on the LCD screen, indicating that the timer is in Random mode. This will cause your timer to switch on and off at different times, following no set pattern.
    • 7 Press the button that looks like a hand with the index finger extended to perform a manual override. The display will show you whether it is in Manual or Auto mode, and whether it is turned on or off. "Manual On" means that the time is switched permanently on while "Manual Off" indicates that the timer is turned off. "Auto Off" activates the program that you have set, while "Auto On" turns the time on until the next schedule "Off" time, after which it continues to follow your programmed times.
    • 8 Press "Clock" and "Prog" at the same time to use the countdown feature. Use the "Hours" and "Min" buttons to select the length of the countdown, and press "Manual" to start.
    • 9 To reset the entire unit and clear all programmed times, use the end of a paper clip or a ball-point pen to press the "Reset" button, located above the "Manual" button.
Read more : http://www.ehow.com/how_5565934_program-kambrook-timer-switch.html How to Program Kambrook Timer Switch eHow
Nov 24, 2011 | Hardware & Accessories
Can you direct me to a user guide? I've moved to
The advance button send the current program to the next state. So if you have 3 on - off cycles programmed per day and you are currently at the second on cycle then by pressing advance the program moves to the second off part of the cycle and will stay off until the next on command time is reached. So if you are on Heating the advance will only affect the heating. Similarly if you are on Water then it will only advance the water program.
Sep 29, 2009 | Hardware & Accessories
Lost instructions for TE 109
1. Press and hold SET until day flashes. Use arrow keys to set
2. Press SET again and hour should flash. Use arrow keys
3. Press SET again and minutes should flash. Use arrow keys
4, Press SET again to exit time-set mode.
Sep 25, 2009 | Solar Ingraham 20 Program Electronic Timer...
Users guide for panasonic cordless hand set kx
users guide for panasonic cordless hand set kx t4027 do not know how to program in new numbers need users guide
Jul 21, 2009 | Panasonic Lands Phones
Ecosse Pegasus Payphone User Guide needed
999/112 is not solved in the tariff settings it would indicate either a flat battery , a coin jam, or lack of time and day programming
Mar 24, 2009 | Lands Phones
We had a power outage and have lost ringing on every phone appart from 1. We have had this before and program codes had to be put back in. Where can we get a copy of these codes to program?
You need to know which phone system you have. Your Norstar phone can work on a few different Norstar phone systems that all set up and program differently.
Once you determine which system you have you need a "Programming and Installation" manual for the system NOT a "user guide"
Feb 06, 2008 | NorStar M7310 Corded Phone
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
