Question about Home
I purchased a pair of shears from QVC in July and the spring loaded scissors are broken. Can I get a replacement?
    Top Expert:
  • 8,204 Answers
Yes you can as long as you can prove you bought them from qvc.
Posted on Dec 06, 2016
While mowing the drive belt tightner spring broke. I bought a replacement but the blades will not engage. The drive belt has been routed properly. it seems as though the blade's drive shaft will not spin.
Check and see if the shear pin has broken. If the pulleys spin but not the blades then the shear pin in the pulley or shaft has broken.
Mar 30, 2015 | Garden
Which is the best kind of kitchen shears?
This article (http://www.cooksillustrated.com/equipment/overview.asp?docid=27679) considered different kinds of kitchen shears of different prices and found that the best shears would be longer but balanced. That would come apart for cleaning, but only after they'd been opened 120 degrees. With a good grip on slippery food. Strong blades but not too hard to close.
My personal suggestion is the KitchenAid shears, that you can find here:
http://www.amazon.com/Kitchenaid-Classic-Shears-With-Black/dp/B0050U240O/ref=sr_1_1?s=home-garden&ie=UTF8&qid=1381749011&sr=1-1&keywords=shears
or the Ergo Chef shears:
http://www.amazon.com/Ergo-Chef-Function-Come-Apart-Scissors/dp/B009PBSDNG/ref=sr_1_9?s=home-garden&ie=UTF8&qid=1381749011&sr=1-9&keywords=shears
Oct 17, 2013 | Home
Stihl HS45 hedge trimmer runs fine, blades move well, does not appear to cut hedge - what could be the problem ?
Dull blades! Lol, or they're not meeting eachother on each reciprocating stroke so there is no shearing action, much like a pair of scissors. Check to see if the blade bolts are too loose or is the blades are warped or if the cutting edges are simply too dull
Sep 24, 2013 | American Gardener Rh25 18" Readyhedger...
I have an ariens 824 snowblower that needs shear pins. How to replace. Where to purchase them. I live in Hyannis Ma. Nick
Most times when a shear bolt/pin shears, the outer ends fall off into the snow, the inner part of the bolt stays inside the auger shaft. You must rotate the auger/ribon to find the hole in the shaft that has the bolt left in, and then with a drift punch, drive the bolt out of the shaft. Depending on the amount of rust, rotation may be difficult. Depending on the shear bolt, finding the internal broken part may also be difficult, but you should see a 'fresh metal shear' of the broken bolt. You can purchase them on eBay or your local lawn & garden dealer should be able to get them.
Dec 22, 2009 | Ariens Garden
Automatic load leveler
The load leveler will be located on the rear axle. It will mount to the axle and have a scissor arm that extends to the body. This replacement is fairly simple, remove the mounting bolts on the axle and then unclip the scissor arm off of the body and re-install new part. Pay attention to where the scissor arm is mounted.
Apr 07, 2009 | 2002 Pontiac Bonneville
Front Springs
I spoke with the Saab dealer whom sold me the springs last March, he told me there is an ongoing problem with many owners having to change springs, I have bought 2 x new springs and had them fitted total costs incl repair of damaged tyre £450, I will not be as originally planning purchasing another Saab, after sales are poor and excuses unacceptable when requested they honour warranty.
Feb 11, 2009 | 2004 Saab 9-3
Excessive noise
I had the same problem. Two things were bad. One was the shock absorber and must be changed out as a pair. Also one of the springs that supports the tub was broken. My guess is that the spring broke and the shock failed shortly after. since it was more easily accessible and appeared to be the problem, I replaced the broken shock. Only to find the spring was broken too. After replacing the spring, its worked fine for a couple of years. Obviously I'm looking at this site because I'm having another problem, but this time I think it is the tub bearing.
Nov 05, 2007 | GE WSXH208A Front Load Washer
Home Logo
46 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
