I have a green box around whatever I try to do and can get out. How do I get rid of it
How to get rid of these pests
It is very difficult to get rid of pest completely. The only way to get the pest out of house is to hire the professional pest exterminators. Once my my friend told me about the pest controller from Larchmount NY. If you want you can checkout Pest Exterminator Larchmont NY
Mar 14, 2016 | Home
Changed crt coolant, better picture. red squiggily line starting at top center of screen, runs about a third of the way down. thought i saw scratch or small crack in green crt "c" lens. would this cau
Sounds like you may have just left one of the wires loose from the red tube. Not likely an issue from the gren tube but you can always cover the top of the lens and let just green shine up. That may help narrow it down also.
Here is more detailed info for you also.....
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jan 17, 2013 | Philips 60P8341 60" Rear Projection...
How do I clean my drafting table cover?
You can use any cleaner to get rid of the marks on the cover. I use whatever spray bottle of cleaning fluid I have around the house. Make sure to clean regularly or your papers will get smudged from the pen marks
Jan 03, 2013 | Furniture
When i turn on x box 360 the green center light appears but the four side lights to not ( no ring). I can open and close the disc on x box but nothing shows up on the tv.
Are your controllers connected to the xbox? that is how you get green light bars around your main green light bar. If you are not refuring to this and nuthing is showing up on your tv screen but you have sound try ajusting/ spinning around the yellow av cord ( Yellow cord is what projects pictures onto screen) . Hope it helped. =]
Nov 03, 2010 | Microsoft Xbox 360 Console
Our Sony Grand Wega suddenly has a green-yellow tint.
IF IT IS HOOKED UP WITH COMPONENT CABLES (GREEN, RED, AND BLUE) FOR PICTURE AND RED AND WHITE FOR AUDIO, MOST LIKELY THE RED ONE IS NOT SEATED PROPERLY, CHECK BOTH ENDS THE ONE CONNECTED TO THE TV AND THE ONE CONNECTED TO WHATEVER THE SOURCE IS ( SATELLITE BOX, CABLE BOX ETC.
Oct 06, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TomTomGo 910 - Green Screen
Mike sounds like an IC glich which is send it back kinda problem if you send it back and they can't fix it they usely send you a NEW one
Jul 15, 2009 | Tomtom GO 910 GPS Receiver
FLOATING BLOCK
hi, it means, u need to change the input mode i.e pal/ntsc/vga..etc or whatever options avilable in the LCD menu..let me know
Dec 28, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
Green screen
replace the capacitor 10/250 volt or all 250 volt capacitors around the plyback section. and check also the supply of RGB it is 180 volt.
Oct 24, 2007 | RCA 20V500T 20" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
