Can u help me solving Bus Error 62 In 1 Kva Ups.Thanks
5 Suggested Answers
  • 1689 Answers
SOURCE: We have a faulty MGE
Most of the failures with these are the batteries. Contact the manufacture for details about having it serviced in your area. They should have the contact information in their instruction manual that came with the unit.
Jerry G.
Posted on Apr 24, 2008
  • 114 Answers
probably u have a board problem, and the repair can be really expensive.
good luck
Posted on Jul 01, 2008
  • 94 Answers
SOURCE: Need to monitor status of Liebert 150 KVA UPS
Try to find your manual here in this site. Choose your Product Category, Product Application, Application Type and Specific Product. After that you can download the manual. Hope this helps. ""
Posted on Jun 03, 2009
SOURCE: need the circuit for 6kva ups with avr
Posted on Aug 04, 2009
?many battries are using in galaxy 3000 g3k
If the Galaxy 3000 is a 10 or 15 KVA UPS, you need 20 batteries of the 12v 20ah if the UPS has standard backup time.
If it is a 20 or 30 KVA, probably it needs 24 batteries.
Talking about the 20 or 30 KVA UPS, if the battery is 34ah, it uses 24 batteries; in any other case it uses 20 batteries.
Jun 19, 2014 | MGE UPS Galaxy 3000 UPS System
Please tell me how many computers a 20 kva ups( liebert )can support.
It really depends on how large your computers are and what they actually require. A 750 W Cisco Server will require usually a 1.5Kva UPS and give you around 7-9 minutes depending on the model of UPS.
Oct 08, 2010 | Liebert 1 KVA UPS MODEL RT1000-60...
How many systems support for 1 KV UPS
1 KVA UPS will provide you good back up with 2 pcs simultaneously without any power fluctuations.
May 24, 2010 | Liebert 1 KVA UPS MODEL RT1000-60...
Bus faul
what is your ups model and KVA rating.. for more solution e-mail me @
Apr 29, 2010 | Powerware 9120 UPS System
Dc bus faulty
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
These lower powered and cheaper KVA type UPS are switch over types, when the mains supply fail, the UPS switches over to the inverter in milli-seconds which then supplies mains power but the power waveform is a pseudo sine wave (ie not a true sinewave. A faulty inverter circuit won’t deliver power when the mains supply fails.
The true UPS types are usually the higher KVA units (over 1500 VA) that supplies uninterrupted mains power. The mains power is connected to a charger which charges the batteries and the inverter draws power from these batteries and converts it to true sine wave mains power therefore there is no switch over time lag from the mains to the battery.
Oct 22, 2009 | Powerware 9120 UPS System
Jun 03, 2009 | Liebert Computers & Internet
UPS 9120
did u check the fuse inside the ups?
did the ups gave the error right after u replace the batteries? or some time after.
sometimes gives the message some time after and its because the charger isn´t working properly. the charger is a spare board in the 9120, 5 and 6 KVa.
good luck
Jun 21, 2008 | Powerware 9120 UPS System
Open Questions:
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
