Question about Dell Computers & Internet
-"Alert! System battery voltage is low. Strike the F1 key to continue, F2 to run the setup utility". Wie bekomme ich die Fehlermeldung weg?
Dell Optiplex 745- Batterie ist Neu. M.f.G. Hini
  • Dell Master
  • 825 Answers
Ed Mac's answer is spot on.
Posted on Dec 11, 2016
  • 781 Answers
To me it seems like your battery is not charging.use volt meter to check output from your adapter or change battery.
Whatever you do do NOT keep using computer until its sorted as you can ruin your windows installation or hard drive
4 Suggested Answers
  • 707 Answers
SOURCE: Have a Dell XPS 600 problem. I am getting a
If you have another keyboard try swapping it out and see if it reads the new one. Also a stuck key could possibly cause this error. System battery message probably means you need a new battery for the motherboard. If you replace the battery get the new one before removing the old one. If you leave it out too long you can clear the CMOS
Posted on Oct 15, 2010
Testimonial: "Thanks alot!!! Very helpful. Thumbs up."
  • 731 Answers
SOURCE: Anytime i switch on my
That warning is referring to the CMOS battery.
Powe off, unplug the machine. Open the case and look for a small round silver disck about the size of a quarter. Read the number on it and purchase a new one. (Should be something like CR2032)
Replacement is faily easy as the old one just pops out and the new one pops in.
You may get an error about Time and Date
Hit F2 to get into the BIOS and reset the time and date
Posted on Jan 03, 2011
Staric
  • 10 Answers
SOURCE: Alert! system battery voltage is
Dell claims the problem is caused by some surge suppressors - and that you can eliminate it by removing the surge suppressor and plugging the PC directly into the wall outlet. Call Tech Support and have them send you a battery, or look in the system docuemtation and go to Radio Shack and get a new one if you are in a hurry.
Posted on Jun 21, 2011
Alert! system battery voltage is low. Strike the F1 ke to contunue, F2 to run the setup utility
Jun 21, 2011 | Dell OptiPlex GX520 PC Desktop
I have a Dell 8200 PC. It is 8 years old. since last week and everytime I restart my PC, I receive this alert: Alert! System battery voltage is low. Strike the F1 Key to continue, F2 to run the setup...
The cmos battery on the motherboard needs to be changed, it keeps the date and time and other functions in check. The battery is silver in color and shaped like a round coin, I would recommend a tech to set up the bios for you to make sure everything is working properly.
Feb 23, 2011 | Computers & Internet
Heloo sir i have a problem with my dell 170l when i start it it shows ''strike F1 to continue, F2 to run the setup utility'' when i click f1 it show ''f1 to retry boot,f2 for setup utility'' plz help me...
Hit F2,look in setup to see if the hard drive is recognized and check that the date and time are correct.
Then hit esc key. it will ask if you want to save changes, click yes. It should boot and probably ask you to hit F1 or F2 again., unless there is a problem with the CMOS battery, which may need to be replaced.
If you hit F1 to continue, it will boot, but your time and date will be off.
Dec 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Have a Dell XPS 600 problem. I am getting a message when I turn on the computer, "Keyboard Failure Alert! System battery voltage is low. Strike the F1 key to continue, F2 to run setup utility." What should...
Oct 14, 2010 | Dell XPS 600 PC Desktop
I had my battery run out, when I changed I get a message that says Strike F1 key to continue, F2 to run the setup utility. When I strike F1 nothing happens, when I strike F2 I enter the bios and I change...
Hi, you will need to perform a windows restore using your windows CD. Insert CD in drive and select the appropriate option. You will not loose any of your work doing this.
Jul 30, 2010 | Dell Computers & Internet
Strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Dec 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Computers & Internet Logo
172 people viewed this question
Alun Cox
