Question about Dryers
The dryer heats up at first but doesn't maintain heat through the entire cycle.
    Problem Solver:
  • 5 Answers
I think you should move it to another place
Posted on Jul 20, 2009
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 09, 2014 | Whirlpool Dryers
No heat in dryer mode
In electric dryers, heat is generated by the heating element. The element is a coil of heating wire enclosed in a metal chamber. Electric current flowing through the coil creates heat and the air being pulled through the chamber absorbs this heat. If the element is defective then it will not heat. It can be tested with a multi-meter for continuity. Unplug the dryer and remove the front or rear panel to locate the element so it can be tested.
The high limit thermostat is a safety device mounted on the heating chamber and is designed to prevent the dryer from overheating when the exhaust vent is restricted. A restricted vent will cause the high limit thermostat to trip or activate, interrupting the circuit to the heating element or gas valve. The high limit thermostat is not designed to activate repeatedly like a cycling thermostat and will eventually fail causing a no heat symptom. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter. If there is no continuity then it will need to be replaced and the restricted vent system corrected as well.
Cycling thermostats control the temperature inside the dryer drum. They are designed to "cycle" the heating element on and off to maintain the correct amount of heat. Cycling thermostats are normally located on the blower housing or elsewhere in the internal airflow ducting. Over time, the cycling thermostat can become defective. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter.
Dec 02, 2013 | Splendide 2100 Vented Washer-Dryer
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Gas dryer, runs fine for maybe 10 minutes than the heat goes off and doesn't come back on...change the thermal kit and no fix
The reason your gas heated dryer starts off heating ok,but a part way through the cycle it is no longer heating as it did when it started,is beacuse the coils that open the gas valve are getting hot and breaking down when they are warm. At start up of cycle the coils are cool,but when the dryer heats up as it runs the coils that are weak can not handle the heat and do not open the gas valve. Replacing the gas valve coils with fresh,strong ones will open the gas valve the entire duration of the drying cycle. All appliance manufactures use the same exact gas valve coils and label them with their unique part number. Having been in the service business i know they are all the same and the part number for the least expensive gas valve coils is 279834
They can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
To replace the coils,remove bracket over them(dont worry about where it says dont grip thats for when dryer is plugged in) unplug them and install new ones,that bracket has notches in it and the coils have tabs that inter lock so they position them self exactly where they fit.
This is what the coils looks like
Aug 25, 2011 | Dryers
Takes to long to dry load of clothes . Have to run it through 2 or more cycles
with this particular call
the first thing i would check is yout exhausrt for proper air flow,,,, make sure you check the entire duct, even i have ben fooled by a clogg down line
if they are drying your heat is working
now you need to adrress the airflow issues
Oct 27, 2009 | Dryers
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
Heat level in dryer
A dryer usually overheats because of a kink or blockage in the duct work, blockage in the outside wall cap, or because of a defective cycling thermostat. The cycling thermostat tells the dryer when to heat and not to heat. Clean any lint from the inner and outer ductwork. You can also remove the vent from the back of the dryer for a load or two to determine if the clothes dry faster or not. If this doesn't fix it, go ahead and replace the cycling thermostat. Make sure to use the appropriate setting to dry the clothes.
Aug 09, 2008 | LG DLG0452W Gas Dryer
Kenmore gas dryer 110.72512101
Check your igniter coil. It sounds like this part could be going bad. Another possibility is that the thermostat is defective. Some dryers have more than one thermostat.
Yet another possibility is that your thermal fuse is faulty.
I would check this webpage for more troubleshooting hints:
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/Whirlpool-and-Kenmore-Thermal-fuse.html
Jan 02, 2008 | Dryers
try your pipes at the back,you may have a split
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
