Question about Home
Saniplus unit for the past few weeks has stopped intermittently then starts back up and clears water in the system after an hour or so - however now the unit has stopped clearing water?
agitateme
  • 88 Answers
SOURCE: 2003 Whirlpool Duet Washer clear water pooling in drum after use.
When the machine is off, there are only two ways water could possibly enter. 1 Check the drain hose install, that it is not installed deep in the standpipe, if the hose is shoved too deep, it can sometimes siphon (rare with front loaders) water back into the machine.
2. Most likely cause, a slow leak from the water valve. Sometimes the water solenoid will not close completely, and you will get a very, very slow leak into the machine.
If not the drain hose, try shutting off the water supply valves when done using the machine, if that takes care of it, you may want to replace the machine's inlet valve.
Posted on Apr 19, 2009
Ganx
  • 113 Answers
SOURCE: Subwoofer JVC TH-M606 suddenly stopped functioning
Hiya, sorry that will have to go in for repair as it sounds like it may be protecting. Could be something loose but that would be lucky. Suggest finding a electronics shop in area that can assist. Best of luck
Posted on Jul 15, 2009
SOURCE: hotpoint CTD00 Tumble Drier: No water in draw, 3x as long to dry
sounds like pump has gone
Posted on Aug 31, 2009
SOURCE: My washer keep showing F1 error and then stop, I
Remove the three screws in the back of the control panel and lift the control panel up. You should see a clear plastic tube to the far right going into a gray plastic box.
There is either a kink or break in this hose or the controller board (the grey box) is bad.
Try removing the hose and blowing in it to check for any resistance (clog).
I just bought a controller and they run about $200
Posted on Jan 10, 2010
Testimonial: "Thank you, I did not see anything wrong with the clear tube, however I forgot to blow into it. I will double check it before ordering the controller. "
citroenchris
  • 600 Answers
SOURCE: my saniflow saniplus has stopped pumping water
We had that problem but the unit was built in and I could not get at it, the outlet pipe sounds like it is blocked, I cleared mine by connecting a pipe from the cold tap to the outlet pipe and flushing.
Posted on Mar 18, 2010
The toilet keeps flushing on its own - every few minutes. What can I do?
Water pressure makes the unit kick on and off, definitely somehow water is draining back into the pump casing creating enough water pressure that it makes the unit kick on and off by itself. You need to inspect the flapper on the flush valve inside the toilet tank (water closet) make sure is closing all the way down or it may need to be replaced. Also you may want to inspect the check valve inside the discharge elbow, the check valve has a flapper that opens towards the back of the elbow and allows the waste to be pumped out; when the unit stops pumping the flapper closes back down to prevent waste water from draining back into the pump. The check valve may be defective or may be obstructed and closing all the way down as it should. You may just have to clean it, it may be as simple as that.
Jan 03, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
The saniflo keeps cutting in even when not flushed
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Jul 14, 2010 | Saniflo & Saniplus& Macerator Pump
Saniplus- after flushing wc, motor continues to run and run.
climatizarea nu functioneaza in sensul ca nu am aer rece ci doar aer cald
Apr 21, 2010 | Saniflo & Saniplus& Macerator Pump
Macerator discharging water out of outlet pipe intermittently checked outlet pipe for blockage but its all clear help im stuck
sounds like a switch problem again. try descaling the unit. otherwise its time for a new pressure switch.
Mar 15, 2010 | Saniflo & Saniplus& Macerator Pump
Saniplus pump runs and pumps a cup of water and
unlikely to be a vent problem - more likely a semi blocked 22mm outlet - hence the problem with the old unit & the new one. Tricky to solve as 22mm pipe runs are too small for conventional pipe cleaners. Some plumbers use compressed air to clear, others us pressured water (jetter) unfortunately it always ends up a bit messy.
Feb 13, 2010 | Saniflo 002/003/005 Saniplus Toilet with...
My saniflow saniplus has stopped pumping water i think- the toilet and bath has filled up with waste water. i have taken the top off the saniflo and blades are working fine but they keep going because the...
May 11, 2009 | Saniflo & Saniplus& Macerator Pump
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
