Question about Cell Phones
When resetting my phone to factory state does my phone stay on the phone?
    Problem Solver:
  • 6 Answers
Ask clearly
Posted on Dec 06, 2016
Got to factory rebot screen and wont turn off
Beginner guide to Android How to setup your phone or tablet
How to Reset Samsung Galaxy Tab to Factory Settings Galaxy Tab Forum FAQ...
When you long-press the power button on Android, this usually causes a forced shutdown.
A hard reset is when you reset your tablet to a state where there is nothing on the tablet except for the default apps and the operating system.
Jan 08, 2015 | Digital Reins 10.1" Inch Android 4.1 Dual...
Need factory reset code for ZTE Z796C MAJESTY
As we can see android operating systems does not allow master reset codes, so what you can do is reset the phone to it's factory state. And by doing this all your personal files will be deleted.
The factory resetting process is:
>>You have to turn off the phone
>>Then you just need to Press & hold volume up home button simultaneously,
>>Then power will on the phone Release volume up home button if recovery menu appear
>>Scroll / locate down to factory data reset menu,
>>Just use volume down to navigate and home button to confirm.
>>Your device will automatically restart and now the phone is on factory state.
Sep 22, 2014 | Cell Phones
Will a hard reset on lg lucid smartphone restore uninstalled apps
Yes, that will make it so that the software will return to the factory state. If not then you'll have to either follow the prompts through the phone menus or boot mode to initiate a factory data reset.
Mar 17, 2014 | LG Lucid VS840 4G Verizon
If i restart my phone will i loose all my picturesc and contacts ?
If you do a factory reset, then yes, you will lose it all. If you are just doing a soft reset, then no. A factory reset returns your phone to its original "out of the box" state. A software reset, or "soft reset" just reboots the phone software, much like the way you reboot a computer.
Dec 05, 2011 | HTC Inspire 4G Smartphone
How do I reset LG P500
Factory Reset on Menu Setting
1. From the main home screen, tap menu
2. Select Settings, then Privacy
3. Select Factory data reset
4. Select Reset phone
5. Enter the password if required, then confirm by selecting Erase everything
Hope this helps,
If the phone is frozen, hard reset it through buttons
1. Turn the power off. If the phone is frozen, pull the battery out and inplace it back again
2. Hold the Home and Volume Down button
3. Press and hold the Power button until the phone turns on
4. Follow the on-screen instructions to hard reset the phone handset
The LG Optimus One P500 will then reboot to its factory fresh default state settings.
Sep 19, 2011 | LG P500 Cell Phone
My daughter entered the wrong pin number into my sons phone too many times and now its locked, it now aks for his google account details to unlock.Problem is he does not have a google account, please can...
For all android devices a google mail account is needed for purchasing apps etc. if he did not set this up and had set the pass code without the email specified the only way to get back into the phone would be to do a complete reset. Before you do this have you tried restarting the device and seeing if it gives you the ability to try to enter the code again, if not here is how to do a factory reset. As stated below this will delete everything on the sd card so i would advise you copy all the files from it onto your computer. the entire process should only take about 10 to 15 minutes depending on the phone sometimes less than this, good luck!
Performing a factory reset (hard reset) If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on. Note: Factory reset will not remove the data and files that are in your phone's microSD card. Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset. Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
  1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button. Note: If you are not sure whether your phone's power is turned off, remove and then reinsert the battery.
  2. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
  3. Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
  4. Press VOLUME UP to start the factory reset.
Mar 27, 2011 | HTC Wildfire Cell Phone
Cant send sms. states memory full. close some applications and try again. nothing is open on phone!
N95 Memory Full Problem can not be resolve by simply restarting or by changing the network setting. You must "Manual Reset" it. Just Turn Off the Phone, Press the *, Call Button, Three and ask another Person to turn on your N95 by pressing the power button. Stay pressing the Three Buttons until the phone fully boot up and ask you to enter Date and Time. After that, youre phone will go back to Factory Setting.
Jun 05, 2010 | Nokia N95 Cellular Phone
Reset to factory specs for blackberry curve 8330
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Thanks.
Jun 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do i reset blackberry curve 8330 to factory settings
Dec 28, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
