Question about Dryers
One of my six mercury glass globes will not turn on. We can get it to light by pushing on the base cover, but cannot keep the connection.
The other five are doing great. Perhaps I can order a new base for the globe?
    Top Expert:
  • Dryers Master
  • 49,071 Answers
Perhaps calling an electrician would solve this quickly and not unreasonably priced
Posted on Dec 06, 2016
How to remove a light bulb cap from overlocker sewing machine
There are two ways to do this Agatha, and I have done it both ways.
Pull the glass globe of the light from the base. Use a dinner knife to push into the bulb base until it grips, release a little and turn anticlockwise.
Pull the glass globe of the light from the base. Use a pair of needle nose pliers and grip the edge of the base between the jars. Whilst maintaining grip, twist the pliers anticlockwise. This will roll the thin base around the pliers, loosen the base in the fitting and make it very easy to unscrew.
Put a little Vaseline or oil on the new bulb threads and don't overtighten it.
Let me know how you get on Agatha by way of COMMENT below my post.
Jul 10, 2016 | Bernina Sewing Machines
How do you change light globe in simpson evolution 904 oven
The glass cover definitely unscrews anti-clockwise, but mine was impossible to start moving by hand. I used a pair of adjustable pliers and while the glass cover is made out of pretty thick glass, I didn't want to be squeezing it so I set the pliers jaws to exactly the same width as the glass cover. Because the glass cover has 4 bumps set around it, the pliers jammed on them so I was able to unscrew it.
BTW, the globe under the cover is also a screw mount job - if you're looking for a replacement, keep in mind that it has to be a max of 25W.
Oct 26, 2010 | Ovens
How to replace the headlight bulb or fuse .how do you take out the bulb or f;ilament when headlight stops working
1.Find The Cover Of The Lamp In The Engine Bay.
2.Remove The Round Cover Turning It Left To Unscrew
3.Remove Base Holding Light
4.Take Out Light From Base Usually By Turning It Or Pushing It Out Of Its Clip
5.Replace Globe (Be Sure Not To Touch Globe With Dirty Hand's)
6. Reassemble Light
Mar 14, 2010 | 2004 Pontiac Grand Am
I cannot remove light cover on ceiling fan to replace globe
There are usually small screws around the outside of the globe that screw into a recess on the globe with a rubber ring around it to keep the screws from hitting the glass.
Dec 31, 2009 | Sewing Machines
Bulb replacement 0 how do you get the glass cover off?
The globe is held on by three metal tension clips holding the globe to the base. To remove the globe, you need to pull down on the globe gently but firmly. Try pulling down on one side and then the other, sort of "wiggling" the globe off. Getting the globe back on can be a bit of a challenge, calling for you to get all three clips aligned in place before pushing the globe back up. A little patience and the job will go smoothly.
Hope this helps. If it does, please leave feedback! That is the only way I know if I am being of assistance or just wasting my time.
Oct 10, 2009 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Cant remove Globe to change light bulb on Hampton Bay ceiling fan
twist counterclockwise (looking up at it) on glass firmly and carefully, the globe functions like a screw
Mar 28, 2009 | Hampton Bay 24002 Ceiling Fan
Light burnt out
There are two ways to remove the globe. one is there are screws on top of the glass. two is you grab the glass and turn it counter clockwise. and some tomes there 3 metal clips that hold it in place you just need to pull the glass globe straight down.
Good Luck
Dec 27, 2008 | Dryers
Hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Sep 04, 2008 | Hampton Bay 24002 Ceiling Fan
Remove light globe from simpson harmony nova oven
The glass cover is a screw in. You will need to remove this by turning anti-clockwise to get to the globe.
Jun 01, 2008 | Ovens
How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Dec 29, 2007 | Dryers
Dryers Logo
107 people viewed this question
Top Dryers Experts
