Question about Whirlpool GEW9200L Electric Dryer
Not drying as quickly, requires 2 cycles
Two years ago when new, this dryer as awesome.  Everything dried quickly and before a wash cycle was completed.  It still dries my loads but now requires 2 full cycles.  The washer is running well, spin cycles seem fine and clothes are well wrung at completion. My question is how to trouble shoot the problem? It's not broken but clearly something is not working as well as it used to.  Any thoughts?
  • 41 Answers
Look inside your lint trap to see if it is clogged. Also remove your vent hose to check for clogs there and at the outlet. make sure your hose isn't kinked.
Posted on Jul 20, 2009
  • 3,600 Answers
Heating element may be bad looking at the parts for this dryer it has two types one with a double elemnet so check what the first two gentalmen said then you may have to buy heating element.
Posted on Jul 26, 2009
    President:
  • 1,723 Answers
Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
How do I machine wash my futon cover?
You should wash your futon cover separately from other items. You need to ensure there is room in the machine for it. Avoid using detergents containing bleach. Wash the cover using the cold wash/cold rinse cycle (unless label inscription suggests otherwise). After the wash cycle is complete, you can put the cover in the dryer and tumble dry on a low-heat setting. I like to remove the cover halfway through the drying cycle to flip it to ensure that it dries evenly.
Aug 01, 2012 | Furniture
How to spin dry
Hi there
A short history Around fifty years ago the washing machine and the spin dryer were two separate machines. After that came the twin tub, where the two machines were put into one, then we got the washing machine-front loaded. As well as the dryer. Now we have got the dryer and the washing machine combined.
My guess is that you have to push a spin button and decide which speed you want the spin.
good luck
Kolbrun
Apr 15, 2012 | Washing Machines
Dryer heats up, but does not dry clothes. Vent is clean
As you can see, your heating element has 5 heating coils. If one or more of these coils have opened you dryer will still work and heat but not at well as it would if all coils worked together. You can check each coil with an ohm meter to verify if one or more is open.
Jan 01, 2012 | Kenmore 64742 Electric Dryer
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Clothes too wet after spin cycle
could be the clutch slipping not releasing the brake allowing it to get upto full speed
Feb 28, 2010 | Kenmore Washing Machines
Dryer won't shut off. Heats fine. Timer advances on air dry only. Vent is not clogged. Can't find moisture sensor replacement part.
https://www.repairclinic.com/Shop-For-Parts/a8b104d87061/Model-CYE2000AYW-Magic-Chef-Dryer-Parts
The dryer requires cycling of the heat to advance thhe timer on auto dry cycle. see ,link provided parts and repair guidance. Always remove from power supply first.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Sep 30, 2017 | Magic Chef CYE2000 Electric Commercial...
Dryer not drying clothes anymore!!
Get the power company to send a repairman out there. The power surge mess up the controls.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Whirlpool ET8CHEXSQ Dryer
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Cant use dryer
Hi Haziel,
Is it that you want to dry only or wash 'n' dry straight through in one go?
If it's to dry only...
1. Switch the machine on
2. Press the Auto Dry or Timed Dry button until the neon light illuminates.
3. For Auto Dry press the button for 2 seconds to achieve the neon indicator to light up. then press the button until the glow is beside the level of drying you require.
4. For Timed Dry press the button until the time you require is in the display.
5. Press the Start/Pause key to start the cycle
Please note: in the Timed dry any time above 60 minutes will be displayed as 70, 75, 80, 85 etc. but then will be shown as 1:10, 1:15, 1:20, 1:25.
For wash 'n' dry straight through...
1. Switch the machine on.
2. Select the fabric.
3. Change the temperature or spin speed if necessary.
4. Select any extra options if required.
5. Follow the above to achieve the drying accompanied by the wash.
6. Then press the Start/Pause button to get the cycle under way.
There is a downloadable PDF of the user manual for this machine on the Service Force website, if you require the programming sequence guide, which, is covered in the user manual, should this explanation prove unhelpful.
I hope this does help you
WD Pro
Feb 17, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
Whirlpool GEW9200L Electric Dryer Logo
184 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
