Breezeair Harmony 2 water runs out intermittently when unit is turned off.
Hot water is intermittent
YOU PROABALY HAVE A BAD THERMEL COUPLE OR BAD HEATTING ELEMINT OR MAYBE THE PILET LIGH IF GAS IS TO LOW. IF ELECTRIC IT MAY BE SET TO LOW OF HAVE A BAD CUT OF AND ON SWITCH
Feb 27, 2014 | Camp Chef Camping, Backpacking & Hiking
I have a harmony 890. it turns all the equipment on/off properly except the TV (a Vizio). this works intermittently. suggestions?
Hi. Try learning the power commands for your Vizio TV from the original remote. The power commands that the Harmony remote is using may not be correct. The following tutorial by Logitech will assist you with this.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9605
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Jan 15, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
1 unit intermittently shuts off and other won't ignite
if you have the exhaust run together it will not light up,, they have to be seperate,, the computer board sences the unburnt gasses and will not allow it to start,,
Jun 24, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Display shows "Harmony safe mode" and will not respond/turn off
remove one battery. press and hold the #2 while replacing the battery. hold the #2 until you see "upgrade success". press activities and you're back in business.
Mar 07, 2009 | Logitech Harmony 550 Remote Control
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
