Question about LG Televison & Video
How to connect LG K7 wifi to 32"Element TV - LG Televison & Video
How do I get my LG smart tv to connect to Wifi
change your WiFi security setings in your router from WPA/WPA2 to WEP.
Go back to the Smart TV and reconnect to your network with your selected security key.
It may be less secure but it may be the only setting your tv will recognize.
Sep 11, 2017 | LG Computers & Internet
How do I connect LG K7 to HDTV
You need to buy chromecast or any similar device. Connect it to your hdtv using hdmi connection. While wifi is on, you can cast what your watching in the phone by pressing the cast symbol on your phone screen.
you can also try pressing the google home icon in your phone and select cast your phone to your tv.
There are lots of video samples in casting your phone to your tv using chromecast or other similar devices like roku, etc in youtube.
Mar 02, 2017 | LG Televison & Video
What cable do I use to connect my LG K7 to my HDTV
hi hdmi or usb or bluetooth if the tv as it thanks
Lg k7 will not turn on just stays black
RIKKI, Check the attached links,instruction and guides on getting your device back and running. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix Android device wont turn on problem
LG K7 How to Hard Reset my phone HardReset info
LG K7 Hard Reset For Metro Pcs mobile
My phone wont turn on
Jul 06, 2016 | LG K7 4G LTE with 8GB Memory Cell Phone
How do I get and send MMS on my new LG K7?
Reviews are not good on that phone!
Mixed reviews here. I certainly does texts SMS!
So then I did a chat with a T-Mobile agent!
You: Does the LG K7 have MMS Multimedia Messaging System capability?
Darwin: Thank you for the opportunity to assist you today.
Come on Darwin. Time is money :>) Darwin: Yes, this supports MMS! Darwin: I am sorry about the late reply. Darwin: The LG K7 definitely has MMS capability. Darwin: This is a great Android smartphone to start with. You: Thank you. This is a question that has been asked on I will reply. Thanks I was only joking. How does the consumer bring up the MMS interface? Darwin: This found on Settings under Text Messaging option. You: Thanks, you are a star!
LG K7 Read Reviews Tech Specs Price More Mobile
May 05, 2016 | LG Cell Phones
Can not connect tv to my home wifi
A what stage does it fail to connect?
As general advise double check your wifi connections settings, that your wifi router is on and connected to the internet.
Mar 20, 2014 | Insignia IS-LCDTV32 32 in. Television
How do I connect my K7 to a 1394 socket
Your Pentax K7 lacks firewire (1394) connectivity, so a connection to a fireware jack will not be possible without purchasing an inexpensive Firewire to USB adapter . From the manual:
Available Ports:
  • USB 2.0 hi-speed, AV out, HDMI out, DC in, cable switch, 3.5mm stereo microphone.
  • Video out: HD (1080i30, 720p30, 480p30), NTSC, PAL
  • Printer interfaces: n/a
The I/O (input /output) panel on a Pentax K7 camera.
You can connect a USB cable from the "PC/AV" on the camera to your computer's USB port with an appropriate cable to transfer image files for editing, etc. Additionally, you can send video directly to a TV with an appropriate cable via the camera's HDMI jack.
I hope this helps!
Oct 04, 2013 | Pentax K7 Digital Camera
How to connect LG 42LD520 to wifi
get the wifi access code and input into the wifi client of the tv.
heres the manual
Apr 15, 2013 | LG 42LD520 42 in. HD-Ready LCD TV
Can I get wifi through my LG 50? If so How?
Hi Judy -
I from what I've seen your LG 42LG50 TV does NOT support wifi connectivity. CNet has a review on it - and has a specifications page - and there is no mention of it there or in the user reviews. Additionally, the LG website indicates the TV has been discontinued, and makes no mention of wifi either. Since the TV was a 2008 vintage, I would expect to see a lot of hype about the TV being wifi capable - and this is simply not the case.
I hope this answered your question and good luck! Please rate my reply - thank you.
Mar 13, 2011 | LG 42LG50 42 in. LCD HDTV
Just bought an open box LG LED 42 inch TV. I got a couple questions. 1. What is the recommended way of cleaning the screen? 2. How do I get it to recognize my wifi? 3. Please provide me a link to an...
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
From the manual, here's what it says about cleaning:
thomascha103_1.jpg And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
thomascha103_2.jpg That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
Best of luck!
Jan 12, 2011 | LG 42LE5400 42 in. LCD TV
Televison & Video Logo
32 people viewed this question
Computer Repairing
Computer Repairing
