Question about Garden
Adjust the mower deck
Front of deck shaving lawn back 2 inches higher
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at or you can go to and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
  • 123 Answers
SOURCE: Craftsman 42 inch cutting deck riding lawn mower.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Posted on Aug 28, 2009
  • 472 Answers
SOURCE: Self propelled mower no longer propells
Posted on Oct 01, 2009
Mower deck adjustment mtd 13538
Are all the rods that hold the deck on all the same length. Has any been replaced with the wrong ones. Did this machine hit something that things were bent an out of shape.
Are your tires blown up where they should be? Soft tires will do that.
Dec 06, 2016 | Mtd Garden
YT4000 blades not turning
I am wondering if you have the right belt for that machine. or possible its not installed properly.The belt should be tight when engaged. The tightener may not be working as well. These are things to check. Does the belt try to tighten up when you engage it?
I am wondering if the wrong belt was the reason why some one lowered the deck too low.
Apr 28, 2015 | Craftsman YT 4000 42" Briggs Stratton 24...
you may have bent brackets in the front. These are the pieces that straddle front and back of the front axle beam. This happens when you hit things sticking up or on the side with the deck.
You also could have bent deck link bars (where you make height adjustment on the front).
Aug 12, 2014 | Craftsman Garden
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
How much space between front of deck and rear how do you lower rear
if you are talking about leveling deck front to back, no more than 3/8 in higher in back to adjust put tension on front hangars ,so u want to tighten front hangars hope this helps
Jul 10, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Husqvarna 54 inch rider, fairly new, bought used. Deck will not fully lower or raise even after levelling per manual. Are 54 in decks more susceptible to this type issue?
the Rake adjustment is critical on this mower make sure the front to back is within 1/4 inch of each other with front being the lower this adjustment is on the front if its a single rod the bracket that attaches it to steering axle is probably sprung back this happens from running the mower into something with the deck.
Dec 02, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Hower do you do the adjusting for height on the
The dial only sets the height or the total deck, it is more of a stop than an adjuster.
If it seems too low in the front, you can adjust it by tightening the nuts on the 2 bolts/pins that are attached to the deck and the frame.
First of all, though, check your tire pressures, 10 psi in the rear and 14 psi in the front. If front pressures are too low, this will make a huge difference in your cut. You want to adjust the bolts an equal amount to maintain your side to side level keeping in mind that it should have 1/4 to 1/2 " difference front to rear.
Make your adjustments on your driveway or garage floor so you have a flat level surface to go by.
If you make these adjustments and it still scalps, you will either have to set the deck to cut a bit higher or approach the high spots from a different angle or remember to lift the deck up a bit with the handle when you get to those areas
Hope this solves your problem
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftman 20 1/2 with 42 inch cut deck is leaning more to the front how do you adjust
If you look at the front of the mower there are two rods that attach to the front of the tractor frame. On these rods there are 3/4 nuts that are the mower rake adjustment.First start by positioning one of the blades to a front/rear orientation. <easure the height of the blade from floor at the front part of blade and then the rear.The front measurement should be a maximum of 1/4 inch lower than the rear. Loosen up the lock-nuts on the adjusting rods and turn the nuts clockwise,this will pull the front of the mower deck up.
Jul 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
