Question about Motorola Walkie Talkie 2-Way Radio
HOW DO YOU GET THE WEATHER CHANNEL ON WALKIE TALKIE?
  • Motorola Master
  • 1,654 Answers
Your radio must have VHF capability, as weather channels are VHF. Then your radio must be programmable to the weather channel for your desired area. If you repost a question including your Motorola radio name/model, we could be more specific.
Posted on Jul 20, 2009
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
How to use radio in my walkie talkie
press & hold "mode" then use the channel up & down button until you hear it, depress the PTT to return to normal
Apr 19, 2014 | Cobra Microtalk 100 FRS Walkie Talkie...
Uniden walkie talkie says L every time I push a button
You've set the keylock feature on your walkie talkie. From the Uniden manual...
KEYLOCK
ON/OFF Press and hold the call/lock key until the "L" appears. After 1 second, the LCD will return to the channel display. To exit Keylock on mode, press and hold call/lock again. Note: While in keylock on mode, it will still receive transmissions.
Feb 10, 2014 | Uniden Radio Communications
I cannot get my bellsouth walkie talkie model 2290 to unlock from a channel
The manual says to press and hold the MODE button for 5 seconds turn on or to turn off the LOCK mode. When locked, it prevents you from accidentally changing channels.
Jan 05, 2013 | BellSouth 2290 Walkie Talkie FRS/GMRS...
How do I change channels on a uniden walkie talkie
Press the channel-up/down buttons. See the items marked 3 and 4 on the illustration in this manual.
Mar 11, 2011 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
I have the cobra micro talk with rechargeable batteries my workers plug them up every night and get them in the morning but some arestill saying low battery, does the walkie talkie need to be turned off...
they charge better if they are turned off. since they do not have a paid dedicated channel, signals can
still be received by any walkie talkie using the same channel, and can deplete the charging process
to the radio. good luck!
Dec 07, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Is there a way I can change the channel on my Walkie Talkie manually. I can't get them both on the same channel.
On the Motorolas you have to press the menu button until your current channel flashes. Then press the plus (+) or minus(-) sign to change the channel. 21 is a great channel and you can get distance on it.
May 10, 2010 | Motorola Walkie Talkie 2-Way Radio
Is Bell South walkie talkie compatiable with other
Some number their channels differently, but all FRS/GMRS radios operate in the same mode and will have at least some frequencies in common. Check the channel/frequency lists for both radios and you'll be able to talk to each other.
Feb 28, 2010 | BellSouth 1061 (14 Channels) 2-Way Radio
Assigning the frequency to channel on walkie talkie
plse contact a service team,
www.laradio.com.za
Mar 30, 2009 | Radio Communications
Radio Communications Logo
194 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
