Led24d20 desing mod - Televison & Video
TCL LED24D20-BL. What is the service menu opening code?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name and type of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 05, 2015 | TCL 24 in. Hdtv
Acer h274HL turned off whilst I was on it and Wont turn back on? solutions please.
hi,
acer h274hl has obviously desing problem at power on/off switch.
it's mecanically very weak and break's it self before end of life whole product. Mine power switch broked after 2 years.
Depending on your location and legistalation monitor should work over 3-10years and manufacturer is responsible to repair OR GIVE NEW product, waranty or quaranteen from manufactory dose not affect rights based on your legistlation.
For Acer this is realy bad advertising.
You can remove switch and use microswitch behind rear panel by screw driver if you do not have time to start war against your computer merhant or Acer. Going service due switch takes 1-3 hours time so most likely you buy new monitor or remove switch.
I did not found replacement switchs from ebay so it is not solution eighter.
Also remeber all bad products and avoid brands whit bad desing.
Here is one link which might be helpful:
https://www.youtube.com/watch?v=mZjoeRoVGXI
So, you are not alone!
Apr 03, 2013 | Acer H274HL TV
When I try to download music from pc to my ipod, pc says connect
Hmmmm check wit the data cable once.. try using different USB ports els different data cables itself..
- if cable workin fine den try doin a hard reset.. i.e with d iPod plugged in 2 d comp try resetting iPod..
-Els check if ya iPodz getting recognized in iTunes.. if itz gettin not gettin recognized reinstall the itunes software.. or follow dese steps-
1>www.apple.com
2>Click on the tab SUPPORT
3>Select iPod+iTunes
4>Select iPod nano 4 r 5th gen
5>U'l find many divisions as get started troubleshooting n al.. under troubleshooting d 3rd link i.e iPOD DOESNT APPEAR IN ITUNES n follow d steps
-if itz gettin recognized in iTunes n not gettin recognized in comp den follow d same steps til troubleshooting.. under dis go to d 4th link i.e iPod is not recognized properly by computer when USB drivers are not installed properly r out f date..
Try wit al dese steps.. hope sumthin works out 4 u..
If none f dese work den derz another step to it.. may b disk mode step which am not sure f.. try finding out regardin diskmode n may b dat'l help ya..
May 26, 2010 | Apple iPod nano
What is the operating temp for the 1993 bmw 325i
The working temperature of the engine will be according to set type of thermostat you have there dese 174F (79C) to 207F (97C)
Feb 27, 2010 | 1993 BMW 3 Series
Tie rod right side
this is a common problem, there are new desing tie rods avail.
Dec 30, 2009 | 2002 Ford Escape
Need to change color of front of dishwasher
Try Applianceart.com. They have a ton of options in colors and desings
Dec 25, 2009 | Bosch Dishwashers
I want to code for a button that saves values....
i think ur talking abut vb go to desing mode double click the command button type add give space and follow the promd
Sep 19, 2009 | Microsoft Computers & Internet
Computer freesing
get more ram for your pc, or a better processor. or even get xp instead of vista.
Nov 28, 2007 | Microsoft Windows Vista Ultimate Edition
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
