Question about Epson Expression XP- 605 Inkjet Multifunction Printer - Colour - Photo/Disc Print - Portable Printer, Scanner, Copier - 32 ppm Mono/32 ppm Color Print - 12 ppm Mono/9 ppm Color Print ISO - 20 Second Photo - 5760 x 1440 dpi Print LCD - 1200 dpi Optical Scan
Epson xp-605 switches off
I turn my printer on and it goes through it initial setup procedure then awitches straight off, any ideas peeps
    New Friend:
  • 5 Answers
Someone at SuperUser contacted Epson and was told to turn off the WiFi router (break connection), then disable Google Cloud Printing. That had mixed results.
Others found it easier to disable WiFi on the printer, then disable GCP.
Posted on Dec 07, 2016
  • Amanda Kinnett
    Amanda Kinnett Dec 07, 2016
    I have the same problem with my Epson WF-2530. The only thing that has gotten it to stay on for any time at all is disabling the Wi-Fi. But I need to have it on Wi-Fi to print!
    I tried going to my printer's IP address to disable Google Cloud Print but my printer won't stay on long enough for me to suspend or delete it. Is there another way?
  • Amanda Kinnett
    I managed to disconnect it from GCP through the IP address in one of my many attempts while the printer was looping. Disabled Wi-Fi so the printer would stay on, then I was able to restore default settings. Turned Wi-Fi on and I was able to print. Thanks so much! I also did a little reading on SuperUser to get more info. I appreciate the help.
5 Suggested Answers
  • 47 Answers
SOURCE: I have purchased a new
havent seen this printer, but i'm guessing reinstalling the software may help...if not, mebbe there is a reset button.
hope this helps!
Posted on Apr 08, 2008
SOURCE: swap black inks with Epson 9800
By using Colorbyte's Imageprint software and their 'Phatte Black' cartridge....
I have not purchased it myself quite yet but im good friends with an Epson R&D guy who tested their system and highly recommends it.
Posted on Apr 16, 2008
  • 461 Answers
SOURCE: Epson FX-2190 Matrix Printer
No, only one time installation is sufficient. You might see problem if you install wrong driver on the wrong O/S..
You may find details information about epson FX at
HOpe this helps.....
Posted on Sep 09, 2008
  • 4 Answers
SOURCE: Epson Aculaser CX11NF Printer is offline
you need to go to settings ,then printers then right click from your mouse on your printer ,then put it online..thats it...i hope it will work..
Posted on Mar 25, 2010
The printer was working fine, then I printed a test print and it was very faded. All the cartridges were almost empty except 1. I replaced all the cartridges. It shows me they are all full, but when
Hi Sharon,
This may be an error. Shutdown the computer and re-seat cartridges to be sure they are connecting to the cartridge carriages properly. Once cartridge replacement procedure completes, close all the access panels.
Now shut off the power to the printer by unplugging it or by turning off the power bar it's plugged into. Don't use the printer's power switch!
Now, plug the printer back in. Reboot your computer. And then, turn on the printer and let it complete the initialization process.
Hope it will help.
You can also follow us for more info and support
Epson Printer Support Epson Technical Support Epson Phone Support Online...
Dec 01, 2014 | Epson Stylus 1400 InkJet Photo Printer
Printer freezes up
You should also check that is not a driver problem, by reinstalling the drivers from lexmark.
Mar 13, 2008 | Epson Stylus Photo 1280 InkJet Printer
How do I start up my Epson printer 605
Have you tried pressing the power button? If that does not work you can either take it back or call Epson for service.
Sep 16, 2014 | Epson Photo Office Equipment & Supplies
Epson PX650 not printing the full A4 page of my receipts, cutting off on right hand side
Nov 18, 2013 | Epson Aculaser C1100 Printer
Epson expression xp 600 error code 0xEA when setting up
I had the same problem today. I opened the printer below the scan bed, where you install the ink cartridges and there was a piece of packaging material that got left in that while I unpacked. I removed that and the 0XEA error was gone. I was sure the problem was nothing to do with the cartridge installation as it was the initial setup of the printer and cartridge installation was the next step based on the user guide. I was getting this error on initialization after setting the region, date and time.
Jul 24, 2013 | Epson Expression Premium XP-600...
Cannot share my epson cx4800 windows xp
It is possible that you do not have the setting set properly. The link below will help you make sure you have the printer share setup properly.
Let me know if you have any more problems or questions
How to setup and add a shared printer in Windows XP
Jan 26, 2010 | Epson Stylus CX4800 All-In-One InkJet...
How do i eject the ink carrier?
hi there,
  1. Look at the Epson printer's LCD screen to see the ink levels for each cartridge. If your cartridge is completely empty, simply press the "Color" button. If your cartridge has a low ink level, press "Setup". Hold down the button on the upper left side of your LCD screen until the words "Replace Ink" appears, then press the "Color" button.
  2. Wait until you see the words "Open the scanner" on the LCD screen. Then lift open the printer top by pulling up on the side grips next to the scanner unit. Make sure that the scanner lid remains closed. The ink cartridge holder should move to the far right of the printer.
  3. After the cartridges have completely stopped moving, pull the cover of the ink cartridge holder up and toward you. Press in the tab of the cartridge you need to replace. Lift the cartridge straight up to pull it out of the holder.
  4. Unwrap the replacement cartridge and insert it securely into the holder. Press straight down until the cartridge snaps into place.
  5. Close the cartridge holder cover and make sure it clicks into place. Close the scanner unit and wait while the printer charges the new replacement cartridge. Wait until the word "Charging" disappears from the LCD screen before using your printer.
Do not turn off your Epson printer while the "Charging" message is still on the LCD screen because this may cause your inks to not fully charge. Turn off your printer only if there has been no response for over five minutes.
Clean up any ink spills with soap and warm water.
Replacement ink cartridge: Black (T048120); Cyan (T048220); Magenta (T048320); Yellow (T048420); Light Cyan (T048520); or Light Magenta (T048620)
Hope this initial info/idea helps.
Let me know for further instructions.
Apr 29, 2009 | Epson Stylus RX500 All-In-One InkJet...
Connecting wi-fi on Epson SX600FW
I hada the same problem. I used the settings on the actual printer rather than through the software to input the information it needed and It works fine now. I was able to set it up on my husbands laptop without any problems, I just added his laptop through installing the software on his laptops as it had picked up the signal and was showing in the Network and sharing centre on Windows Vista premium. Hope this helps. I think you need to take the wire out now and now load it as wireless. You need to use the wire first to connect then take it out to connect to the wirelss network. My router is a Sky router.
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Epson Expression XP- 605 Inkjet Multifunction Printer - Colour - Photo/Disc Print - Portable Printer, Scanner, Copier - 32 ppm Mono/32 ppm Color Print - 12 ppm Mono/9 ppm Color Print ISO - 20 Second Photo - 5760 x 1440 dpi Print LCD - 1200 dpi Optical Scan Logo
118 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
