Question about Toshiba Computers & Internet
I have a toshiba satellite laptop Intel, i factory default it and now it don't get past the boot menu, it says that the software is corrupt or missing. How Do I get past that screen.
  • Toshiba Master
  • 10,263 Answers
I hope you have the restore CD's for that laptop. Restoring wipes the hard drive and makes it ready to reinstall the software on the CD's. If you don't have a set, you might be able to get a set from Toshiba's website.
Posted on Dec 06, 2016
    Top Expert:
  • Toshiba Master
  • 25,693 Answers
Use your Windows Disc, or purchase one, to reload windows,
SOURCE: Toshiba satellite a105 s4004 cannot boot
if the recovery disk would not run to load the program than your hard drive is probably bad have you been into the machine and seen the hard drive have a look at the front where the wires plug in and there is a slot for jumpers to select the hard drive function make sure its set for master only. most hhard drives will not have a jumper for master setting if there is a jumper make sure its set right .
Posted on Dec 08, 2007
  • 71 Answers
SOURCE: Toshiba Satellite won't boot up
While you have it in safe mode, make sure you back up all your personal data to a cd as is sounds like it is not going to last much longer. After you back up all your information....Documents, Pictures, Music...etc... Then I would reformat the machine with the original installation disc that came with the computer. That should fix the problem. Never even heard of a boot processor :)
Posted on Oct 10, 2008
crashmech
  • 67 Answers
SOURCE: Toshiba Satellite a135-s4427 Boot Manager Missing
its not the hard drive my frined, its the boot loader it has been deleted or it has been compressed the only way to fix this is to use the recovery cd you have, to boot from cd-rom you need to go into bios which is usualy F2 or F5 key, then under boot manager or somthing is the primary and secondary boot, change the primary to CD-ROM, then save it and restart then it should boot from cd-rom then you have do a start-up recovery.
Posted on Jan 22, 2009
kbdesign
  • 370 Answers
SOURCE: restore factory settings on toshiba satellite S1800-3545 laptop
You can follow LavaTech's instructions to set the machine to boot from the cd, and you can load any retail version of windows. You will have to go to http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support
to download and install the device drivers.
Posted on Mar 18, 2009
kbdesign
  • 370 Answers
SOURCE: Toshiba Satellite A60, reset to defalut...how?
With that machine, the recovery disks came with it when new. You can, however, install any retail version of the operating system, and go to www.toshiba.com to download/install the required device drivers.
Posted on Mar 22, 2009
How can i reset a toshiba satellite pro m15 s405
Most Toshiba laptops with come with the factory software recovery image stored in a special hidden partition on the hard drive of the laptop. The factory software recovery image allows the user to recover the laptop to its factory fresh condition as when it was new.
This partition may also be referred to as the Partitioned Recovery Method or Free Recovery option.
IMPORTANT: The recovery process deletes information stored on the internal storage drive. Be sure to save your work to external media before executing the recovery.
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. On machines with the F key numbers on the top edge of the keys and in White:
    • Press and hold the 0 (zero) key and power up the laptop.
    • Release the 0 (zero) key when the recovery warning screen appears.
    On machines with the F key numbers on the bottom edge of the keys and in Gray:
    • Power up the laptop.
    • When the initial TOSHIBA screen displays, press the F12 key to enter the boot menu.
    • Use the arrow keys to select the HDD Recovery option and press the enter key to begin.
  5. The TOSHIBA recovery wizard warning screen appears stating that when the recovery is executed all data will be deleted and the original factory software image will be rewritten. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. After you are sure you have everything you want from the laptop saved, click Yes.
  7. When the Toshiba Recovery Wizard opens, the default and recommended option is "Recovery of Factory Default Software".
  8. After selecting your desired recovery method, select Next.
  9. On the next screen you may have recovery method options. The default and recommended method is to Recover to Out of Box state.
  10. Select next to continue.
  11. Follow the on screen instructions as you navigate through the system recovery steps.
  12. The laptop will restart multiple times and install the needed components.
Nov 25, 2014 | Toshiba Satellite Pro M15-S405 Notebook
How to reset Toshiba A215 to factory defaults
You may follow the below steps to restore your Toshiba A215 laptop to its factory defaults:
Turn the Toshiba Satellite A215 computer off.
  • Press and hold the "0" key. Turn the computer on.
  • Release the "0" key when the Toshiba Recovery Wizard screen appears.
  • Click to select "Recovery of Factory Default Software" and then click "Next."
  • Click to select "Recover to out-of-box-state" and then click "Next."
  • Click "Next" on the confirmation screen to begin the recovery process.
  • Press any key on the keyboard to restart the computer when prompted. The computer boots up to the Windows setup screen.
  • Hope this helps..
  • May 20, 2014 | Dell Inspiron Mini 10 Notebook
    Can't get Toshiba Satellite L775 to boot past "windows is loading files" screen
    I assume you are doing a System Restore/Recovery? Have you removed the HDD and tested it? Perhaps the Recovery files are corrupt/missing? A bit more info needed.
    Jul 03, 2013 | Toshiba Satellite L655-S5160 Laptop PC...
    How do i reset my toshiba satellite L305-S5955 to factory default & erase all data from it?
    Close out any software currently running on your Toshiba Satellite L305 laptop.
    Navigate to the laptop's "Start" menu and choose "Shut Down."
    Hold down the laptop's "0" key and press the power button.
    Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen.
    Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option.
    Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again.
    Wait for the "Press any key" prompt to appear and tap a key to restart the laptop.
    Use the prompts that appear on the screen to choose your region, time zone and keyboard settings.
    Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system.
    hope this helps
    Sep 06, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
    I need to reset my laptop
    Hello, here are the steps to resetting your computer.
    Reinstall Windows from a Disk
    1 Turn on your Toshiba Satellite. Insert your recovery disk or the original Windows operating system DVD
    into the Satellite's CD/DVD drive. Turn off the computer.
    2 Turn on the Toshiba Satellite. In the first few seconds while it is starting up, press and hold the F12 key on your keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to press "C" to boot
    from the CD-ROM). The screen will display boot for this boot up session only.
    3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this setting is for this session only; it is not a permanent change.
    4 Allow the computer to start up. Follow the onscreen instructions for reinstalling the operating system from the disk.
    Reinstall from a Recovery Partition
    1 Boot up the Toshiba Satellite. In the first few seconds while it is starting up, press and hold the F8 key. This will begin the "Advanced Boot Options" menu.
    2 Use the arrow keys on your keyboard to navigate the menu. Move the keys to select "Repair Your Computer." Press "Enter."
    3 Select your language and keyboard; click "Next."
    4 Select your Windows user name from the drop-down menu. Enter your password if required. Click "OK." This will begin the "System Recovery Options" menu.
    5 Select the Toshiba Recovery Wizard and follow the onscreen instructions. The Toshiba Recovery Wizard will delete all existing data on the hard drive and reinstall Windows.
    Hope this helps!
    Mar 28, 2011 | Toshiba 173" Satellite L555S7008 Intel...
    WAY TO RESET TOSHIBA SATELLITE L305-S5955 TO FACTORY SETTINGS WITHOUT REBOOT CD
    1. Close out any software currently running on your Toshiba Satellite L305 laptop. Navigate to the laptop's "Start" menu and choose "Shut Down."
    2. Hold down the laptop's "0" key and press the power button. Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen.
    3. Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option.
    4. Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again. Wait for the "Press any key" prompt to appear and tap a key to restart the laptop.
    5. Use the prompts that appear on the screen to choose your region, time zone and keyboard settings. Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system.
    Read more: How to Restore a Toshiba L305 ' eHow.com http://www.ehow.com/how_7292537_restore-toshiba-l305.html#ixzz15nMSp0YB
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    Nov 20, 2010 | Toshiba Computers & Internet
    The previous hard driver was bad. I replaced it with a new hard drive. I used the Toshiba default factory setting to reinstall the softeware and now my laptop will not boot up.
    Toshiba default factory setting can only restor your software if you have backup copy on New Harddrive.
    As your old Harddrive crashed, you have to reinstall Operating system and requie software on new Harddrive.
    Mar 09, 2010 | Toshiba Satellite P205D-S7454 Notebook
    Put in recovery 1st recovery disk .2nd recovery
    Toshiba Factory Reset
    1) If you have a recovery partition on the laptop - have a read here to see if you have one http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=recovery+to+factory 2) This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
    If that option is NOT available then you will need to Order CDs from Toshiba - http://laptopforums.toshiba.com/t5/System-Recovery-and-Recovery/Recovery-media/m-p/9148#U9148
    Jan 11, 2010 | Toshiba Satellite L45-S7423 Notebook
    A friends toshiba satellite A120 has corrupted it can not get past the log in screen and we do not know what to do
    Turn on the laptop and keep pressing F8, it should take you to a boot menu. From there choose safe mode and see if you can get to a login screen there, if you can get past that login screen and get into windows safe mode then go into the control panel and under users you should be able remove the user accounts you don't want. Then you can reboot the laptop and you should be able to get into windows then normally.
    If you try to go into safe mode and can't get past that login screen then your going to need a program to remove the passwords manually for you.
    Here is a program to help you with that:
    http://home.eunet.no/~pnordahl/ntpasswd/
    Its a free download and just follow the instructions to create the cd and then boot the laptop off of the cd and follow the directions on screen.
    Sep 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
    PC will not boot.
    Hi , without explaining all that is happening ,your pc harddrive has failed.The pc is looking for an operating system but cannot find it.
    Dec 08, 2008 | Toshiba Satellite A135 Notebook
    Computers & Internet Logo
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
