Question about Epic Exercise & Fitness
Epic view 55o lift bar does not lock - Epic Exercise & Fitness
  • Epic Master
  • 6,694 Answers
If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Dec 06, 2016
Why doesn't it start?
epic view 550 treadmill video 2 - YouTube
? 2:08
Mar 9, 2010 - Uploaded by Epictreadmillowner
epic view 550 treadmill video 2 ... ICON Canada doesn't really support this and the independant technicians ...Epictreadmillowner 1,181 views.
Epic View 550 Treadmill Review - YouTube
? 3:02
Nov 29, 2012 - Uploaded by Treadmill Review Guru
... .com/epic-treadmill-reviews/epic-view-550-treadmill-reviews-ratings/ ... Nordic track has the track and google maps by i-fit you can download and run anywhere ... The review says it doesn'thave the track/lap but it does.
Epic View 550 Treadmill video 3 - YouTube
? 1:59
Mar 11, 2010 - Uploaded by Epictreadmillowner
Epic View 550 Treadmill video 3. Epictreadmillowner ... I have had 3 different console units, and now the tv doesn't work either!
Epic View 550 Reviews -
Jan 27, 2016 | Epic View 550 Treadmill
Treadmill deck will not fold in the storage position
HOW TO FOLD THE TREADMILL FOR STORAGEBefore folding the treadmill, adjust the incline to the lowest position. If this is not done, the treadmill may become permanently damaged. Remove the key and unplugthe power cord. CAUTION: You must be able to safely lift45 pounds (20 kg) to raise, lower, or move the treadmill. 1. Hold the metal frame firmly in the location shown bythe arrow at the right. CAUTION: To decrease the possibility of injury, do not lift the frame by the plastic footrails. To raise the frame, bend your legs, keep yourback straight, and lift with your legs. Raise the frameabout halfway to the vertical position. 2. Raise the frame until the latch knob locks into the storageposition. Make sure that the latch knob is locked in thestorage position.To protect the floor or carpet from damage, place amat under the treadmill. Keep the treadmill out of direct sunlight. Do not leave the treadmill in the storage
position in temperatures above 85 Fahrenheit.
Jul 15, 2012 | Epic View 550 Treadmill
Can I lift the vacuum beater bar higher up? Bought new carpet and would like it to push smoother!!! Bought a shag carpet
No. The Electrolux (Aerus) uprights are auto adjusting to the height of the carpet. Make sure the brush is spinning when the vacuum is on. If it's not, this will cause difficulty in use.
Apr 06, 2011 | Electrolux Epic 3500 Vacuum
The speed reading on my epic 55o treadmill quit working. I can see what the new setpoint speed is and the treadmill accelerates/decelerates to the new speed but the actual speed always reads 0.0. This...
Under the motor cover, on the left side mounted on the frame is the speed sensor.
It is a little black "bullet" shaped thing clamped to the frame with a wire wrapping around the frame to the electronic board. It may need to be adjusted. Move it as close to the pulley as possible without making contact. If it still doesn't work, inspect the pulley for the 1/2 inch round magnet. It is mounted on the pulley. If it is missing, it may be attached to the metal frame someplace. Place it back into the holder on the pulley and try the treadmill again.
If you still have no speed reading, the sensor will have to be replaced.
Jan 04, 2011 | Epic View 550 Treadmill
I have a new epic 550 and the treadmill will not latch up, in fact I called and got a new latch lock installed it and this one doesn't latch up either. any idea
Did you make sure the incline is completely down? I had a similar problem and then realized the incline was on 2. I recalibrated and then it latched fine.
Dec 13, 2010 | Epic View 550 Treadmill
I am having trouble removing hood/motor cover on Epic 550 treadmill. I have removed 4 - 3/4" screws from front panel and 2 - 1/2" screws from underneath. Still feels locked on. Are there other...
If you lift your treadmill deck up, you will find 2 screws underneath, on the side, towards the front. remove them and that should do the trick.
Nov 23, 2010 | Epic View 550 Treadmill
Our Treadmill belt is slipping. How can we fix it?
hi, if the belt is slipping you need to tighten it, at the back end of the treadmill on the corners there should be two bolts turn them both untill you can only lift 2 to 3 inches of the belt up,
Nov 22, 2010 | Epic View 550 Treadmill
We are putting the Epic 550 together and got to the part about the storage lock. When we try to lift the treadmill into a verticle position, it won't go up far enough. It only goes up about half way. Why?
check and see if you incline is down to zero if not this problem occurs or the or plug it in and if the incline reset itself then it should be o k if not you may have to do a calibration on it
Mar 01, 2010 | Epic View 550 Treadmill
How do you put the treadmill down? We can't seem to unfold the treadmill. It's an Epic View 550. Thanks!
There is a knob on the support bar behind the treadbelt deck. Give the deck a little push up, then pull the knob out and lower it.
Sep 26, 2009 | Epic View 550 Treadmill
Exercise & Fitness Logo
47 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
