Question about Panasonic Heating & Cooling
Our panasonic inverter air con unit won't operate. The remote control shows OFF in the top right hand corner and won't allow us to turn it on? Don't know what to do. model RE/UE9/12QKE
    New Friend:
  • 85 Answers
Try to clean up the remote contacts. replace the battery also
Posted on Dec 06, 2016
  • 67 Answers
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Posted on Jan 23, 2009
SOURCE: Changing the battter of the remote control
Slide the cover down as far as it will go. Now using your fingernail, gently lever the cover off from the base, it will click out without much force. This is a stupid and confusing design and should be changed.
Posted on Apr 09, 2010
SOURCE: Panasonic Inverter CS-E12EKU timer indicator blink.
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Posted on Dec 11, 2010
  • 2133 Answers
SOURCE: air con not working. Operation
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Posted on Dec 31, 2010
SOURCE: Panasonic inverter air conditioner remote control
to replace your battery have 2 AAA batterys and slide down the front cover and pull the cover of the remote you will find the battery compartment underneath the slide.
Posted on Jul 08, 2011
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
I have an lg inverter air conditioner it look like remote 6711a20128s LG nothing showing on controller screen. I changed battery and all symbols show up only 1s then blank, repeat and same Please help
You have a faulty remote. These are considered consumables by the manufacturer so you'll need to get a new one or universal remote. LG remotes are typically pretty cheap though. You should still be able to turn your air con on by the manual button somewhere on the front panel.
Dec 28, 2015 | LG Heating & Cooling
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ... Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Inverter remote
Pull the battery out to rest the the remote possibly has a reset button on the back
Jan 17, 2014 | Panasonic Heating & Cooling
Panasonic p50u20b - picture shrunk into top right hand corner of screen
seems you have found the PiP (Picture in Picture) if you still have the orignal remote press the pip button or the cancel button
Dec 28, 2011 | Panasonic Televison & Video
I have a Panasonic air conditioner model CU-E12EKU (inverter). The unit stop working and the timer indicator is blinking. I checked for this error and followed the instructions in the Operating Manual,...
Not sure if yours has a letter 'H' before the 16 but if it does, it's the:
- Outdoor Current Transformer open circuit.
which means that your outdoor controller board is faulty.
Sep 08, 2011 | Panasonic Heating & Cooling
The buttons on my air conditioner quit working. It will still turn on and off. It is now set to fan. Will a universal remote work with it? I don't want to spend $75 on a remote(replacement remote) that...
I'm not sure there is a universal remote available for AC units. There may be, I just have not seen one. However, you can still operate the unit without the remote, if you do the following. I'm assuming you have changed the batteries in the remote and they were installed properly (i.e. Facing the right direction) and it still doesn't work or you lost the remote.
Turn the unit OFF and unplug it for 15 minutes. Once the time has elapsed, plug the unit back in and turn the ON/OFF switch to ON. The unit should have reverted back to the original factory setup settings. Which should now allow you to operate the unit without the remote, because the controls on the unit should now be activated.
I hope this helped you and thanks for choosing FixYa.
Aug 07, 2011 | Frigidaire FAM156R1A Wall/Window Air...
I've got one single 12000 btu ac unit and one double 24000 btu unit and three wall units controled by 3 remote controls.Recently one of the remotes stoped to work.I've changed the batteries(were...
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | LG LS-K1830CL Cool Mini Split Air...
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Jun 10, 2009 | Panasonic MCM INVERTER
Heating & Cooling Logo
54 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
