Question about HP Office Equipment & Supplies
Hi i need hp mfp 1005 smps circuit str z2062 circuit in smps board smd resitor like code r 502 504 506 pls send circuit giagram
    Habit-Forming:
    New Friend:
  • 85 Answers
Try to find the schematic diagram here : PDF file :www.xtrade.kz/files/parts/HP/mfu/HP_LJ1005mfp_partlist.pdf
Posted on Dec 06, 2016
Hi hpm 1005 mfp prinet power suply circuit str z2062
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of SMPS section of many popular brand devices are given.
Dec 01, 2016 | Televison & Video
Hp laserjet 1005 printer second page paper jam
Hi senthil, my name is Lisa and I would be happy to help you with your Laserjet 1005. I understand you are experiencing a paper jam when printing multiple page documents.
There are multiple variations of the 1005, below I will list 3 links one for each of the 1005 Laserjet printers I think you could have.
Clearing Paper Jam for HP LaserJet P1005 P1006 P1007 P1008 and P1009...
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=1839458&docId=emr_na-c00765431&docLocale=en_US < HP LaserJet M1005 MFP - Clearing jams
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=bpl10965 < HP LaserJet 1000 Product Family - Clearing Printer Media Jams
I hope that one of these links is specific to your printer, and that the appropriate link helps you resolve the issue.
Best of luck. I work on behalf of HP.
Jul 02, 2015 | HP Office Equipment & Supplies
How to fix postcript for hp 1005 mfp printer
Here's the manual.
An encapsulated PostScript (EPS) file does not print with the correct fonts. Cause Solution This problem occurs with some programs. ? Try downloading the fonts that are contained in the EPS file to the device before printing. ? Send the file in ASCII format instead of binary encoding.
http://h10032.www1.hp.com/ctg/Manual/c00682960.pdf
May 18, 2015 | HP LaserJet M1005 MFP Printer
How can i repair str z2062 power supply of my hp m1005 mfp laser printer ?
First of all; it is DANGEROUS to fix a power supply if you don't know what you are doing. Thus; don't even think about to open power supply tower, if you are not qualified enough.
If you are a qualified person, you can go on with below steps by taking risk on your own.
You must discharge biggest capacitors in order to avoid any fatal electrical shock. Even it is disconnected from electricity plug, power supply may keep high voltage in it for long time. Once you discharge big capacitors; you may diassemble power supply tower. At your question you mentioned about burned power supply which makes it a little bit easier. (I assume you discharged big capacitors) Once you open psu tower; do visual inspection on each capacitor. If there is a burned area start with it. Remove blowed capacitors and replace them with same valued new capacitors. If you can't see the values on blowed capacitors; you need to find board diagram of your psu. Otherwise you can't find suitable one to replace. Besides; check form of other capacitors. If there is a change on any capacitor's form, replace them too. The best way to find out dead capacitors is using capacitor testers. If problem caused by another type item; its not easy to find it as finding bad capacitors.
Nov 19, 2014 | HP LaserJet M1005 MFP Printer
Loss my drivers for HP Laserjet M1005 mfp
If you go to H.P's website and go to support imput that you need drivers for your laserjet m1005 mfp. and you will either be able to down load it right away or they will send you an e-mail with it or a link to retrieve one..Good Luck
Nov 15, 2012 | HP LaserJet M1005 Printer
Hitatchi 42pd5000 will not power up
pls. open H-output trangister and out side of pcb and check voltage B+ 135v dc is ok ?.
if yes.then ...H-OUTPUT trangister checked and replace
if not then check SMPS .
1.fuse
2.STR
3.output Dyode
check
1st fuse is open then check rectifier dyode cantunity. if sort then replace all 4 dyode.(rectifier)
and if dyode is ok .then check STR cantunity is sort then Replace with New STR but 1st 220uf/450v dc capaciter cheked / 2nd. in SMPS stage any P.F and capciter likage or sort cheked or chenged first after the NEW STR use
*. note: smps pcb checkd any dry canaction pls. Resolder first.
Oct 04, 2009 | Hitachi Televison & Video
HP 1005 Scanner error 6
dear Sirs i have HP 1005 did't work and have this message Scanner Scanner error 6
please if you can help me
Sep 07, 2009 | HP LaserJet M1005 Printer
How to disable copy in HP Laserjet M 1005 MFP
I will say for me, i would rather uninstall then reinstall with the installation disk where during the installation process you will have options to select the functions you want to install.
Feb 03, 2009 | HP LaserJet M1005 Printer
79 people viewed this question
Seeker5211
Seeker5211
