Question about Freezers
I need help finding a repair/wiring manual for a Defy Chest freezer CH 530-HC. The freezer is basically brand new but stopped working -- the compressor just kicks on for a few seconds, then off.
  • Jennies de leon
    Jennies de leon Dec 07, 2016
    the photo shows the usual and standard wiring of a freezer, the flow of wirings are the same but it changes only on a color coded type and brand of any freezer in the market, but this will guide you to troubleshoot and find the defective part of the system,in your problem,check the starting capacitor first by using multi-tester. if defective replace it with the same value and try to plug-in again and observe.
    Habit-Forming:
    New Friend:
  • 85 Answers
This site will help: https://www.defy.co.za/wp-content/uploads/2016/06/CF365-Chest-freezer-3809550100-AC-G-A5.pdf
Posted on Dec 06, 2016
Testimonial: "Thanks, but this link is for the regular owners manual which give precious little information on troubleshooting, and nothing on repairs or a wiring diagram. Still hoping someone out there has a link to a repair manual."
Defy 130L chest freezer wiring diagram
Do a google search for a wiring diagram for your model
Nov 05, 2017 | Freezers
Chest Freezer Stopped Working 14 years old
The first thing you want to ensure is that power is actually getting into the unit. i suggest that you do that by plugging a night light into the outlet and verify the presence or power. If no power, check your breakers. If power is present note that A chest freezer has only two working parts; the start relay that help the compressor start and a compressor. If you are getting clicking sound, your start relay may be out (inexpensive if you can buy it and install it yourself) or a bad compressor. if you need to call a tech for the repair, you may be able to purchase a new chest freezer that now consume HALF the power and for less than cost of repair.
Mar 02, 2014 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Brand new freezer. power light is on. run light is on. I can clearly hear the compresor running. does not cool at all. ??? help
Chest freezers produce cold very slowly, so it could be an hour or more before you start to feel the cold. If still no cold, ( and I mean absolutley no cold) then you most likely have adamaged refrigerant line and the (freon) refrigerant has been lost. Take it back, or call for warranty repair.
Nov 27, 2010 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Bar Chest Freezer Large
I would think that the reason the red power wire melted, was because of high amperage, not getting wet. After you replaced it the condenser fan came on, but did the compressor? It may have went out before and that's what caused the bad wire. If you have a volt/ohm meter I can help you check it out.
Jan 29, 2008 | Summit Commercial 7.50 cu. ft. / 212 liter...
Kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Sep 25, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezer not working, odd rythmic noise.
Is this the capacitor wires you are asking about perhaps?
Sep 08, 2006 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Freezers Logo
244 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
