Question about Aquabot Robotic Pool Cleaner
My aqua bot will not move
I went out to take my aqua bot out of the pool, i noticed the filter bag inside was half off and there were leaves coming out of his top where the blue cap is so i unscrewed the 4 screws in the cap and cleaned it out and put it back in but it and put it in the pool but it would not work anymore it just scoots two or three inches and then stops it still shoots out water and acts fine its tracks even move but the second that it touches the floor of the pool it stops rotating and scoots a little and stops with his jet stream still working and coming out. i appreciate your help in advance thank you
    Problem Solver:
  • 15 Answers
Check and make sure that there is no debis in the drive belts! If you are near Phoenix AZ I my be able to look at it with you. Also, the website http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Aquabot-Troubleshooting.html may be useful to look at S, Christian dansker01@msn.com
Posted on Aug 22, 2009
Can I fix my input valve, on my sand filter, while water is in the pool?
IF YOUR ASKING IF YOU CAN REPLACE THE MULTIPORT VALVE ON TOP OF SAND FILTER HOUSING WITH WATER STILL IN POOL , SURE ITS POSSIBLE . 1ST UNPLUG PUMP POWER !!!! SECOND USING A COUPLE OF TRASH BAGS ADD ENOUGH AIR INSIDE OF THEM TO FIT JUST TIGHT ENOUGH DOWN INTO SKIMMER ON SIDE (ME I USE A OLD POOL TOY) WEIGHT OF WATER WILL HOLD THEM IN THERE , NOW YOU CAN DISSCONNECT YOUR HOSES , A SLIGHT TRICKLE MAY COME OUT (EASY TO REPLACE LOST WATER VOLUME) REPLACE THE VALVE , WAIT FOR GLUE TO COMPLETLY DRY (IF USED) THEN RECONNECT HOSES , REMOVE TRASH BAGS FROM SKIMMER(LET AIR OUT) , RECONNECT PUMP AND TEST FOR LEAKS
Jun 05, 2015 | INTEX Sand Filter Pump
AQUA LOGIC WILL NOT START UP OR COME ON WHEN FILTER BUTTON IS PUSHED
if filter pump breaker is on if 220 volt make sure both are on if thats ok you need to check the wiring going to the relay if ok you have a bad relay you need anew filter pump relay for the control box they go out ocassionally
Jun 11, 2014 | Hayward 2HP Pool Pump Motor A O Smith...
Will not clean shallow end of pool heads directly to deep end
Make sure that the Floating Handle is locked diagonally across the top of your Aquabot's body.
Clean the Filter Bag thoroughly so that the fine particles of dirt that get trapped within the fibers of the
Filter Bag are removed. To test if the Filter Bag is inhibiting the
Aquabot's performance simply remove the Filter Bag and operate the cleaner without it. If the Aquabot then pumps
water strongly, and climbs the walls properly, the Bag most likely requires a thorough cleaning
Sep 12, 2011 | Aquabot In - Ground Robotic Pool Cleaner
Brand new Aqua Critter, won't move at all? Checked filter, checked hoses? Still will not move? Now what?
It looks like my cleaner. While it is hooked up to the filter, lift the unit, keep the suction side under water and flip it over. The feet should be moving. Feel for suction on the inlet on the underside.
There is a waterwheel inside the suction. Is it rotating? Is the suction hole clear, sometimes stones, acorns or other solid items get stuck in the suction that stop the water motor.
If there is something stuck inside or if the wheel is not moving, on my unit there are a few screws that can be removed to inspect inside. Naturally before doing this, disconnect the cleaner, drain it and take it to a location where it can be partially disassembled to inspect.
Gary
Jul 10, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
Polaris 380 stand on nose while on will not move off
There are several things that you can check on these automatic pool cleaners to try and correct this problem. First, make sure that the filter bag is not full. A weighed down bad can cause the cleaner to tip onto the nose. If there is water in the head float, you will need to replace it. Make sure your hose floats are spaced correctly so that they are not causing the cleaner to float incorrectly.
May 17, 2010 | Polaris 380 In Ground Pool Cleaner
I have a 15 x 4 heritage pool. I am having
It sounds like you have a clog in your pump impeller, If you go into the front of the pump with the basket removed you can get into this with a long nose plier.
Oct 10, 2009 | Heritage Pool and Cover Pump
My acqua bot turbo doesn't move. Can you tell me where the nearest repair service dept is to my home address. Brick, NJ my email is mdaniele23@comcast.net Thank you in advance for your help. Mary Ann...
Ask them directly at:
General Contact Info
Aqua Products, Inc.
25 Rutgers Avenue
Cedar Grove NJ 07009
Phone Number: (800) 221-1750
Fax Number: (973) 857-8981
Email: info@aquaproducts.com
Hours of Operation:
Monday-Friday 9AM - 5PM EST.
Sep 24, 2009 | Pool & Spa
Pool cleaner Won't move
For these automatic pool cleaners, make sure that the filter bags are clean and free of obstructions. Check your impeller. Sometimes hair and other materials can get caught in the impeller and can cause the unit not to move. Finally, make sure that you are getting adequate pressure from your return lines.
Jul 30, 2009 | Smartpool Dolphin Robo - Kleen Above...
My Aqua Critter seems to get clogged up pretty quickly. We just opened a pool that had been closed for a year. There are a lot of leaves in it. Is that why it cloggs so quickly?
It most certainly is.
The simplest solution, is to sort of half the work for it, by collecting as much leaf litter, as you can with a net, before sending in the critter.
Also, a cover, will drastically minimize the amount of litter entering the water.
Have fun fishing:)
Jul 26, 2009 | Hayward Aquabug Above Ground Pool Cleaner...
Aquabot Robotic Pool Cleaner Logo
509 people viewed this question
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
