Question about Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Oil for submersible sump/effluent pump
I have a craftsman submersible pump and i cracked it apart to make an internal electrical repair and dont know what kind of oil its filled with. the pump model number is 390.305790 and is half horepower 115 volt 60 hz 12 amp.
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Posted on Apr 03, 2011
Submersible pump in effluent tank stays on after emptying the tank
The float switch in the submersible pump is stuck. Depending on the design of the switch you may be able to free it up (if you have access to the pump) by subjecting the unit to vibration. That is, whack it a few times :-) If the switch is beyond responding to that treatment, then I'm afraid it may need to be replaced by a pump repair shop. Good luck!
Cheers, Don.
Jul 07, 2014 | Plumbing
Sump pump runs constantly
external float type? move float up and down- should shut off if down - if not - switch needs to be replaced
Dec 22, 2013 | Liberty Pumps 253 1/3 hp Cast Iron...
Step10 pump
you can take the motor off it, but that's about it, there a sealed unit that take high pressure. so if the motor is bad you can buy a new motor OR if the pump is bad you can buy it. there is only 4 bolts that hold them together so its a easy fix If the parts are cheap. kinda
Sta-Rite STEP10 High Head Submersible Effluent Pump 10 GPM 0.5 HP 115V 1PH
SKU:
SRTSTEP10
GOOD luck with it.
Jay the pool pump repair guy in longwood Florida 32750
Jan 07, 2012 | Sta Rite Pool & Spa
Submersible sump pump leaking oil. are repair parts available. Pump is Teel 1p914
If it is leaking oil then the case is cracked and it would be as mush to fix it as to replace it.
If it is fairly new the take it back for a replacement if not you can get parts but the case is not one of them.
The problem is that if oil is getting out water is getting in and the pump will fail very soon.
Mar 01, 2011 | Plumbing
How do you add oil to a sump pump? Do you add it to the water in the pit?
dont add oil to water-- if u have to or want to oil motor get a spray lube unplug unit and at bottom remove debris guard only clips on and spray shaft and behind impeller if need to lube upper motor bearing unscrew housing and carefully pull up enough to lube top of motor replace housing careful of watertight seals and test pump oil poured into pit would only be pumped out and does not contact motor which sits in watertight housing
Jan 25, 2010 | Little Giant Submersible Sump Pump, 1/4 Hp
Little Giant Pump - dialectic oil to use
ck your local yellow pages for an electric motor repair shop they should be able to get silicone oil to add , but in a pinch ive used full synthhic auto transmission oil that works too
Jul 29, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
What oil is inside a 1/3 HP 1725 RPM effluent pump
You can refill it with capella oil. This is the same as the oil used in refrigerator compressors, and be acquired
from stores specializing in refrigeration and airconditioning. Send us an e-mail for further assistance.
Jun 29, 2009 | Submersible Systems Submersible Sump...
Oil type
these pumps are supposed to be sealed and not to be able to oil,,
Jun 28, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
How do you get it apart to install new electric cords?
Not 100% sure about this, but I think you'll find the answer is... you don't.  In all submersible pumps that I'm familiar with, the cable is part of a unit that's sealed during manufacture so that water can't get in to the electrics.  If your cable is damaged, I think you have to replace the whole unit. Sorry! Of course, if you just want to extend the cable, you can get a waterproof connector.
Apr 15, 2009 | Simer 1/3 Hp Submersible Sump Pump
Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP Logo
1,760 people viewed this question
Top Water Electrical Supplies Experts
Paul Carew
Lawrence Oravetz
Are you a Water Electrical Supply Expert? Answer questions, earn points and help others
