Hijackers put piece of paper on rear window of car so you notice it when backing out of parking bay and get out to remove it.
  • Office Equip... Master
  • 10,045 Answers
Sometimes they will put money under the wiper blade too. Just drive off and get it later.
Posted on Dec 06, 2016
I'm trying to copy something and it's saying no paper error rear tray
remove the rear cover, pull out the paper trays and look for any obstructions. Turn it off at the wall while you do this to reset it.
Jul 16, 2017 | Office Equipment & Supplies
REAR WINDOW STICKER used to car jack?
Paper-on-Rear-Window Carjacking Scheme - Urban Legends > Humanities > Ideas and Issues > Crime and Punishment
  1. Cached
Jan 5, 2017 - Viral rumor warns of a carjacking scheme involving placing a paper flyer or money on ... As we drove away I noticed a sticker on the rear window of the car. ... BEWARE OF THIS NEW SCHEME THAT IS NOW BEING USED.
Urban Legend - Car-Jacking Scheme Warning - Paper on Rear Window
  1. Cached
  2. Similar
Sep 5, 2005 - Message warns of a new car-jacking scheme in which paper is placed on the back window of ... BE AWARE OF THIS NEW SCHEME THAT IS NOW BEING USED ... Department: The Paper on the Windshield Carjacking Email REAR WINDOW STICKER used to carjack Google Search
May 24, 2017 | Cars & Trucks
How do you open the rear door to fix a paper jam on a Kodak 5250 printer?
There are two plastic tips that you pinch inward at the lower back of the printer. A rectangular plastic piece will come out if you give it a god tug and you should be able to remove any jammed paper. I took mine off and never put it back on because it is aggravating to remove. I also had a problem of every 5-6 sheets of paper would not feed correctly through the printer and a paper jam notice would be displayed. I have all but remedied this too by stretching two heavy duty rubber band around the paper dispensing tray close to the bottom to provide more tension on the paper feeder itself. WORKS GREAT FOR ME! GOOD LUCK! Mine is a Kodak esp 3.2 but it paper jams a lot so maybe this will help you some as well?
Aug 09, 2014 | Kodak ESP Office Equipment & Supplies
Dell c1760 printer paper jam but don't see any paper. Can't find a place to open to inspect rollers and such. Any suggestions will be appreciated.
Hi Randy,
I am responding to your question you asked four years ago. Today I had the same issue with my Dell c1760nw printer. It would say open the rear door to remove the paper, but i couldn't see any. Using a flat screwdriver, I snapped out the 1+ inch plastic pieces (three of them) and exposed a pair of screws. Then take off the rear door and remove two other screws next to the hinges-holes for the rear door. Now you can snap up the top piece that ll you need is to lift it to expose the fuser area. You should now be able to see possible left over piece(s) of paper. Carefully remove the pieces and avoid touching the fuser. That's all to it.Putting all back together should be easy using common sense. I found a single piece of paper just above the fuser in the enclosed area. I removed that and the printer was back to normal. i hope this helps you or someone else.
Jul 30, 2013 | Dell, Inc Dell Color Printer C1760nw -...
Im not 100% sure about the rear but with the front windows i removed the panel then the foam piece. I then removed the torx screws holding the regulator from the motor itself there were three in the front windows not sure about the back. There were 4 rivits holding the regulator to the door which i had to drill out. Once i put the new regulator in i put new rivits in attatched the window to the regulator via the blue clips and put it all back together.
Sep 15, 2010 | 2000 Volvo S80
When trying to use the scanner to make a copy of a document. The paper jammed, how do you remove it? It said on the glass window to remove the back where the ink containers are. I did that but I cannot see...
There are possible 2 places for the paper jam, either the Feeder has jammed or from the input tray.
For Feeder, you just have to open the feeder from the top and see if there are any pieces sticking in.
Else, you can open the print head cover and look for pieces of paper jammed in it.
Another place you may see is by removing the rear of the printer, it is called a duplexor which can be taken off easily. You may find some bits of pieces in rear of the printer.
To avoid getting another jam, try to keep the paper in a cool and dry place. If the paper absorbs any humidity, it starts crumpling which results in paper jam. You can also try fanning the papers before putting in a bunch and use a recommended paper for the printer.
Hope this helps.
Oct 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Gateway 450sx no power
Needs physical repair. No help without some new parts. The "little piece" latch is necessary. The bay thinks there is a device there and there isn't. The POST (Power On Self Test) program won't allow it to startup if a device is missing.
Jun 18, 2008 | Gateway MT3705 Notebook
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Brother Intellifax 4100
1-pull the paper cassette out-fan the paper and adjust the cassette to the proper size of the paper.2-after you remove the cassette from the machine have a look in cassette bay with help of any light source and cofirm there is no foreign object stuck inside(pieces of paper-pins etc-after that if the problem exist apply a spray from contact cleanr with it is tube inside the bay of cassette in direction of machine rear frame.and insert the cassetee firmly many times to activate cassette switches.
Mar 03, 2008 | Brother IntelliFAX 4100 Laser Fax
29 people viewed this question
