Question about Euro-Pro Sewing Machines
420 euro-pro sewing machine is stuck? tryed to push on the foot pedal & tryed turn the hand-wheel by hand and its serms completely jammed or stuck? I need help to fix euro-pro 420 sewing machine?
    Genius:
  • 1,046 Answers
Have you checked underneath the reed dogs for jammed thread and lit build up?
Posted on Apr 02, 2017
    Top Expert:
  • Euro-Pro Master
  • 51,494 Answers
Check the timing . needle hitting bobbin most likely
Posted on Dec 06, 2016
SOURCE: replacement foot pedal and wiring for Euro Pro
Here's a place that carries all the pedals. Many are used by various brands, and go under different names for different machine companies. The euro-pro manual has the manufacturer's name and the model #, or you can browse the drawings of pedals to match your own. My euro-pro 9110 uses a model also used by viking and huskevarna. This place carries the cords as well.
Good luck.
http://sewingmachine221sale.bizland.com/store/page36.html
Posted on Jul 26, 2008
  • 4 Answers
SOURCE: euro pro 9136 wont work
Could be the drive belt from the motor to the machine is too loose, get a new one. Will the machine turn by hand, if not, then there may be something inside jamming it
Posted on Mar 03, 2009
  • 3 Answers
SOURCE: help me find a manual for a euro pro 7133 sewing machine
I hope this helps. It took some searching but this is what i found. Good luck!
http://www.sharkclean.com/manual/7133_REV_1204_ENG-SP-FR.pdf
Posted on Jan 22, 2010
  • 980 Answers
SOURCE: Toyota 2260 sewing machine. When I press the foot
Chances are you have a small piece of thread stuck in the raceway, turn the balance wheel bac kwards and you may free it off otherwise take out the bobbin and bobbin case and the raceway if you have the type with a drop down gate and clear it.
Posted on Jun 19, 2010
  • 1564 Answers
SOURCE: The hand wheel is hard to turn and sticks on my Euro Pro x 8260 sewing machine and I need the manual
Can't help you with the manual. I've never found a source for a free one. As for the issue with the hand wheel ... that is usually a sign that your machine needs cleaning and servicing. (typically fluff, lint, threads, not enough oil, etc.)
Posted on Sep 01, 2012
I need the manual instru tions for euro-pro x 420
This is where to find what your looking for. http://www.sewingpartsonline.com/euro-pro-sewing-machine-instruction-manuals.aspx
Sep 04, 2016 | Euro-Pro Sewing Machines
The needle is stuck in the Shark 612C model sewing machine, any solutions?
Try http://www.fixsewingmachine. com I also suggest that you clean bobbin case. Now, when needle is "stuck", this requires patience and care in "jiggling" the hand wheel to and fro until needle point begins to clear the jammed area. Carefully snip one thread that moves up under needle and jiggle hand wheel by carefully turning hand wheel toward you to see if you can move the take-up lever all the way up to the UP position. Look at bobbin case area and remove bobbin. Cut bobbin thread and remove bobbin case. Sweep gently with brush underneath case and carefully, gently sweep over the feed dogs, poking very ends of brush bristles into "teeth" area to remove lint, fuzz ball/s, and any loose thread/s. Raise presser foot, remove (possibly bent) needle. Insert new needle of appropriate size for fabric weight. Make sure needle pushed all the way up into needle bar groove, at side to back. Keep presser foot RAISED while rethreading. This allows thread to locate tension discs, and HOLD THREAD TAUT. Replace bobbin, making sure thread is EVENLY distributed on it. Imablanced bobbins cause jams, and bobbins with burrs and scratches can real havoc as well as the hook part of the shuttle where the bobbin fits. Smooth such areas with emery cloth carefully, ever so gently. Hope my suggestions are a solution for you. Jimmy
Apr 06, 2012 | Euro-Pro Shark 60 - 384
My turning wheel to manually move the needle out of fabric is jammed. Should I check the bobin compartment for jammed threads.
Yes, by all means, always turn your handwheel towards you never away from you because you can mess up your timing.
Sep 12, 2010 | Euro-Pro Fast and Easy 420 Mechanical...
Euro pro 9136 wont work
Jan 28, 2009 | Euro-Pro 473
Parts
Best bet is to call and request availability and pricing info as wellas how to purchase. The following link is a request form with an 800#at the bottom you can call...
www.euro-pro.com/euro-pro/feedback.aspx
Aug 08, 2008 | Euro-Pro Fast and Easy 420 Mechanical...
Sewing Machines Logo
98 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
