Question about Health & Beauty
YEU SHENG E209138 30 amp used on two scooter batteries
  • 10,291 Answers
Any brand of battery of the same amperage will work on your scooter. You can google mobility scooter batteries and find many places to get them shipped to you.
Posted on Dec 06, 2016
Vietnamese translation of the song "quand le soleil etait la"
thee you,love you, hear you, strated at his heart,love you, love you ,love you,hear you, what x alanh you please where he vows, name me state luon heart flutter
all you have to do is right click on any foreighn language then click on translate in the drop down box
May 17, 2017 | The Computers & Internet
Yeu sheng e209138 LB serie 7 amp
7 AMP MEAN CIRCIT WILL BE OPEN AT 7 AMP?
Aug 03, 2013 | Televison & Video
Schooter slowsdown that stops after a while schooter starts
I'm assuming you have a full charge on your batteries? The problem is that the charger can be fulled into thinking that your batteries are at a full charge when they are not. The battery will put out he correct voltage so your voltage gage reads right. The battery will put out the correct resistance so the charger will see a charged battery. Chargers work by resistance the lower the resistance the harder the charger works to charge the battery. So the only way to determine the real state of charge is to bring the batteries to a battery shop. Have them load test the battery in your presence if the battery is new. This is not a pass or fail test.What we are looking for is the upper limit of the cranking amps the battery will output.They may tell you this battery isn't supposed to be measured that way because in battery is not used to start a car. Well most of the equipment is geared for measuring car batteries. For what we are doing here it doesn't matter. For my scooter batteries i use two 12v 35amp/hr batteries. Have them grab a new one off the shelf, have them find the upper limit of the amp output. What happened to me is i didn't watch them do this test. The instrument he was using will give you a pass.or fail indication at a preset level of about 150 amp/hr unless you manually input a higher level to test for. This was a new battery and they want it to pass. I had them find the upper limit of a new off the shelf battery by entering higher values into the test instrument until it failed back off on the value until i found it passed. A new battery like the one my scooter uses will put out close to 500 cranking amps. Well when i tested my battery it barely reached 200 cranking amps. So in fact this battery doesn't have the capacity of the off the shelf battery. So as you load it the voltage goes down. My motor controller will detect that and give me a fail indication.
oK if this is not the problem we can look for amp leaks. Put a amp meter between the battery and the load. Turn the scooter off, get a reading?.If you do something is either on or a resistive short drawing down your battery. Disconnect stuff until the reading is zero. What ever you disconnected last will give you the section of the scooter the problem is coming from. Like if you disconnect the control head and it drops to zero i would start there. Turn the scooter on there should be an indication, but it should be under an amp. Now get the rear wheels up so that they can rotate freely. Apply just enough power to move the wheels. Look at the meter if its a analog meter does it jump around. Does the motor stall at any time. If the first thing happens you have a partially shorted winding in the motor. IF the second thing happens the meter will jump up or down indicating either an open or shorted winding.
Now floor it jot down the amp draw. IS it excessive? We check this by doing the math. My scooter use two 12 v 35 amp/hr batteries hooked in series. So i have a 24v system @ 35amp/hr, the scooter has a loaded range of 25 mile at a speed of 5 mph.So my battery life is going to be about 5 hours. So we can say the motor loaded on a flat surface will use about 7 amp/hr. So running the motor flat out unloaded is going to be less than 7 amp/hr. My scooter's motor runs at about >5 amp/hr unloaded. Hope this helps
Apr 26, 2012 | Health & Beauty
Wont hold a charge for long
Scooters Logo
Print
Email
Flag
Problem with Scooters
schooter slowsdown that stops after a while schooter starts
Posted by avatarLeonard Cannon on Apr 26, 2012
+ Add a Comment
Suggest a Solution
Solutions (1)
Apr 15, 2012 | Electric Mobility 3 Wheel Motorized...
My Scooter (Fisher & Paykel - Columbus) Will not charge
Hi. These machines will not charge themselves if the batteries are too flat. The charging system is run by the micro processor IC in the scooter. If the battery voltage is too low the the IC will not have enough voltage to operate.
Remove the batteries from the machine and charge in parallel on a 12 volt charger. Once they are charged, put them back in the machine, and try the scooter on charge again.
Good luck. Neil.
May 15, 2010 | Health & Beauty
Batteries are finished. Replace them with fresh ... battery life is about 2 years.
Mar 28, 2010 | Health & Beauty
Battery won't hold a charge - go-go elite travellor scooter battery charged overnight but won't hold charge.
We have had problems with scooter batteries from time to time and the repair man said to take apart the battery case and disconnect the batteries and use a car charger. I put the two battery in parallel and used a amp battery charger. This worked fine.
Don't run your scooter batteries all the way down when using the Go Go as the scooter charger won't always bring them up to full charge and you may have repeat this. Also running the batteries all the way down shortens there life.
Mar 19, 2010 | Pride Mobility Products Go-Go Elite...
What battery is used for the Sheng Bang HD-1688 clock. It is an unusual size.
I do have a Clock with a Sheng Bang HD-1688 Clockwork. There is a normal AA 1.5V battery in it.
Kind regards Marcel van ****
Jan 31, 2010 | Hammacher Schlemmer Brian The Brain
I'm trying to figure out what kind of battery a schwinn electric scooter takes it is a s-180
Your scooter uses dual 12-volt, 10-amp hour sealed recyclable lead acid battery.
You may want to open below link to see some examples of batteries suitable to your scooter.
http://www.batteriesplus.com/products/78-0/6069-Electric-Bike-Scooter-Battery/252604-Schwinn/S180-Electric-Scooter/1.aspx
Regards,
Jeep Brainy
Sep 11, 2009 | Transport Schwinn Rechargeable Portable ...
Scooter battery problem
lots of things come into it driving up steep hills,useing lights,but you can get a larger amp hour battery witch make it last longer
Sep 28, 2008 | Amigo Rd 3 Wheel Scooter with 33AH Battery...
Health & Beauty Logo
69 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
