Question about Allpower Electrical Supplies
I have a 6000 watt allpower generator that the 12 volt breaker poped out reset it still no power replaced the avr ran for about 5 seconds then poped the 12 volt breaker again what could it be
    Sergeant:
    Habit-Forming:
  • 153 Answers
Barry,
The 12v system does not go through the AVR. It most likely is the Battery Charging Rectifier has failed. This controls the voltage from the 12v feed from the alternator and charges the battery.
1) Follow the wiring from the 12v socket/connectors until you come to a Block rectifier. It will be held on by a bolt in the center and have 4 wires connected to it. If you look at the pins you will see one is seated at a different angle to the others. Test the feed to this pin, you should get a result of between 12 Volts DC to 16 Volt DC.
If you are not getting these results then the Block rectifier has blown and will need replacing. http://www.generatorguru.com/rectifier-98406168/
2) If all is testing fine above, then you will need to test the Battery Charging Rectifier as you have an Electric Start and Battery on your unit. This is a metal block located on the back of the engine, next to the starter motor and it has fins running across it. ( to see an example of this part look up your generator on this page http://www.generatorguru.com/all-power/) Again this should be giving you between 12 Volts DC to 16 Volt DC.
3) Next,check the voltage going into the Battery Charging Rectifier from the alternator. You should get between 12 Volts DC to 16 Volt DC.
For replacement parts please see our web page. You will need the full model number to do this.:
Posted on Dec 06, 2016
  • Barry Bordeau
    Barry Bordeau Dec 07, 2016
    Hi thanks for the info. but it does not have a starter or a bridge rectifier it as 3 plugs coming from the stator one to the avr the 2 in to the panel i disconnected the 2 gray wire plug and the 120 volt works but not the 12 volt could it be the 12 volt breaker gone bad
  •  Generator Guru Parts
    Would you like to call our engineers? We have a number of engineers who have worked a number of times on these units. When you call ask for the "All Power America" specialist. :)http://www.generatorguru.com/ask-the-gur...
  • Allpower Master
  • 10,137 Answers
What 12volt load do you have connected to the 12volt connector? You may be overloading the circuit.
Testimonial: "No 12 volt or 120 at all soon as i start it it pops"
  • 1 more comment
  • Lawrence Oravetz Dec 06, 2016
    Ahh, OK. The diode rectifier is most likely shorted internally.
  • Barry Bordeau
    thanks for the info but it does not have a bridge rectifier i unplug the 12 volt widings and the 120 volts work don't no were to go from here
  • Barry Bordeau
    Barry Bordeau Dec 29, 2016
    you were right the rectifier was in the eletrical panel and not on the generator head
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    How many volts is 1200 watts
    Watts to volts doesn't translate as they are different units to measure things. Watts is a power measurement while volts is what is trickling through the cable. You could have 12 volts at 6000 watts or 240 volts and 5 watts, depends on usage. If it's for a car audio amp, it will be generally 12 volts to power it which at 1200 watts means it will run at around 100 amps current according to ohmslawcalculator.com
    Oct 14, 2014 | Car Audio & Video
    My Multiquip GA6HA generator only puts out 1 volt any ideas for troubleshooting?
    Sounds like the alternator has failed, possibly a short or open in the windings. Similar to problem I had with my 10 KW unit. I replaced the alternator.
    Jul 05, 2014 | Multiquip GA6HA Recoil Start 6000 Watt...
    How many 5 watt outside lights can you power with a 20 amp breaker?
    Volts x amps= watts.
    20 amp breaker x 125 volts = 2500 watts.
    However, electrician use the 80% rule, so multiply 2500 x 80% = 2000 watts.
    So if you have 20 amp breaker, and 12 gauge wire, and 20 amp switch, and distance is less than 150 feet, then watt load is 2000 watts or 400 5-watt bulbs.
    Keep in mind that most switches are 15 amp, and not 20 amp.
    Recalculate for 15 amp switch = 1875 watts x 80% = 1500 watts or 300 5-watt bulbs.
    Jun 22, 2012 | Home
    I have a briggs and stratton 8500/5500 generator which I am using to power an air conditioner on a camper trailer. I just recently started having a problem where the one circuit breaker keeps tripping when...
    Hello, First figure out what the load per leg is on your generator. Are you using the 240 Volts because this is two 120 AC volts legs and they are 120 degrees out of phase with each other.
    You will need to figure what the power factor is for each phase on this generator. To figure the power/wattage by using ohm's law. Voltage times Current will give you Watts. Example: If the generator is generator 240 volts the maximum current available is about 23 amps. The maximum current for 120 volts will 46 amps. Therefore, the maximum current per 120 volt circuit is 23 amps for one circuit and 23 amps for the second 120 circuit..
    I would try replacing the circuit breaker with the same amperage breaker. Also, watch what the generator load is per circuit. You can install current meter for each circuit. This will give a good indication of which circuit is pulling more load than the other circuit. GB...stewbison
    Sep 06, 2011 | Briggs & Stratton Power Products 5,550...
    My generator turns on but, supply's no power?
    You must check:
    1. Are your breakers ON?
    2. Measure the voltage on generator terminals.
    3. If the voltage is less than 20 V AC, you should check the excitation field, rings and brushes, AVR - rectifier, cables and fuses.
    4. If every thing is OK you may need to recharge the DC field with a short connection of "+" and "-" of a 12 V battery to respective field terminals when the engine is running.
    5. If the AC voltage raises for a second and drops when you disconnect the battery - the excitation circuit is bad.
    Jul 13, 2010 | McCulloch FG7000MA 7000 Watt 13 HP 389cc...
    High voltage
    Great, JP. Could I ask you to please rate my assistance. Thanks very much!
    Charlie
    Aug 20, 2009 | Coleman Powermate Powermate 5000W...
    Protection light blinks and beeping
    it has been through an overload (hence the protection light) and needs its breaker to be reset (look for a poped out button and push it back in) or it needs a new fuse (replace ONLY WITH THE EXACT SAME MODEL OF FUSE or it will either blow too early or too late (or not at all) when there is a surge.
    Aug 17, 2009 | Monster Cable Monster Mobile PowerStation...
    How do i flash my generac 5000 power plus generator
    well I have a special flasher unit but I believe you can put 12 volts to the brushes while it's running. That should do it.
    Apr 09, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
    No electrical output
    probably your AVR card is burnt...
    an AVR card is located right outside the stator...looks just like an AK-47 clip (i don't know how else to describe it)...i put a pic below this.
    replace it and check again
    466fecd.jpgAVR location
    168ff0f.jpgAVR card
    Dec 28, 2008 | Electrical Supplies
    Electrical Supplies Logo
    57 people viewed this question
    Top Allpower Electrical Supplies Experts
    Craig Butler
    Craig Butler
    Steve
    Gene Haynes
    Are you an Allpower Electrical Supply Expert? Answer questions, earn points and help others
