Where should the router button be pointing when timing a 4.3 Voted
Where does the rotor button point to when timing a 4.3 voted when you have the number one at top dead center?
It should point to the contact just before number 1 cylinder, once motor running you should set ignition timing with a strobe
Dec 05, 2016 | Cars & Trucks
Where is the access point on a pixma mg5422
Do you have a wireless router that has a 'WPS' button?
If so, press that button on the router, and press the similar button on the PIXMA, and the two devices should connect.
Jul 06, 2014 | D-Link DIR-625 (790069292637) Wireless...
After changing the SSID and password I can no longer access my 192.168.01 its says incorrect password but I havent change it
Try This:
Enter the SSID pass code. If that does not work reset your D-Link to Factory Default settings
See Blow:
1. Turn off the router
2. Locate the Reset button on the back of the router.
3. Use a paper clip to press the Reset button and power on.
4. Hold for about 5 seconds (don't hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
5. After you have completed the above steps, the router will be reset to the factory default settings
Jul 25, 2012 | D-Link Dlink Dir-600 Wireless Router...
Hi i'm unable to use my belkin 54g as anything other than a wired connection my laptop and wii sometimes don't even find it as an access point when it does it won't let me connect with or without a...
Wau let me resolve it for you.
o restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the back of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
do this operation 3 times after this your router will go to factory settings
after go to command prompt and ping router like this.
ping 192.168.2.1 and press enter
you will get 4 reply same and 4 packeges= send / 4 packeges= receive and /0 packeges= lose
is you receive this answer you are ready to configure your router again.
also please type .
ipconfig and press enter the answer need to be like this
ip address 192.168.2.2 sample
subnet mask 255.255.255.x
and default gateway 192.168.2.1
good luck and please rate me techbelkin
Oct 26, 2010 | Belkin (F5D7230-4) Router (587009)
I lost my set up disc for my belkin n wireless router . F5D8236-4
If you can't obtain a copy of the disc go to the Belkin web site (http://www.belkin.com/support/), find your router model and download the user manual. Read the "Alternate Setup Method" section. The Belkin manuals have lots of configuration information so you'll need to read through a bit of tech stuff but it's all there. Here are a couple of tips not mentioned tho ... first, find the reset button and press it to clear all previous settings and, second, unplug the router from the internet before doing any of this. Once you press the reset button the router is no longer password protected and anyone can access it from the internet. The chance that someone is scanning the 'net for your router at that point in time might be small but better to be safe than sorry.
Sep 19, 2010 | Belkin F5D8236-4 Router
On belkin surf router clicked on set as access point. then i tried to change it but my computer cant get internet from the router so i cant access the belkin homepage. can u help
the only thing you need to do is reset your router to go the IP address original 192.168.2.1
because when you setup it as a access point the router change the Ip Address.
2. Press and hold the reset button on theback of the router
do this for 3 times and you will acces your router.
Good luck
Please rate me techbelkin
Aug 02, 2010 | Belkin Wireless Surf Router (F7D2301)
Can not access ip address
Did you try to unplug the power for 30 seconds and plugging it back? you can also bring the router back to factory settings... usually that's accomplished by having the power cord removed, holding the reset button in WHILE plugging the power cord back into the router. Keep the reset button pushed in for atleast 30 seconds! Now you should be able to access the admin page. Keep in mind, any time you move an ethernet (network) cable from the cable modem to the device (pc/laptop/router), you have to unplug the power and plug back again 30 seconds later.
Jun 15, 2008 | Belkin (F5D7230-4) Router (587009)
2 routers
Well if you have no way in getting your router to work, no matter what setting you use, i would strongly suggest getting a new router.
-By the way try a NetGear router because that are voted by Geeksquad and Firedog to be the most dependable and longest lasting.
Mar 13, 2008 | Computers & Internet
Wireless access point
try hitting the restart button on the router and or unplugging it for 10 full seconds. then logging back in. Also might want to try Internet explorer (no-addons) or other web browsers.
Nov 14, 2007 | Belkin (F5D9230-4) Wireless Router...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
