Question about Video Game Consoles & Games
My Warma Towel towel heater stopped working. It had been working on and off for the past few weeks, now isn't working at all. Can this be repaired? Model W572
  • 2712 Answers
SOURCE: How to Install Towel Ring
Place the mounting bracket against the wall and trace around the inside of the two ovals on the bracket. Gently drill a hole into the center of the traced oval. If you hit a stud, you will not need the anchor. Carefully tap the drywall anchors into the holes. Screw the bracket onto the wall, using the screws provided, into the two anchor points. Make sure the set screw is backed out far enough to set the escutcheon over the mounting bracket. Place the escutcheon over the mounting bracket, top first. Tighten the set screw with the Allen Wrench provided.
Posted on Aug 27, 2008
  • 2712 Answers
SOURCE: How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
  • 10865 Answers
SOURCE: New Warmrails Towel Warmer Stopped heating
call the company directly at 877-927-6724. Explain the problem and they will assist you or replace your unit.
Posted on Feb 19, 2009
  • 634 Answers
SOURCE: how do I remove the towel bar from the wall?
on both ends look underneath and there is a tiny hole with an Allen/hex head insert u turn counterclockwise wise and loosen srew until you can tilt end upwards towards the wall, reverse to install
Posted on Jul 17, 2009
  • 129 Answers
SOURCE: How can I remove 24"
for most towel bar and bath accessories there is a very small screw or allan bolt, located on the underside of the post, which holds the post to the mounting hardware and you can simply unscrew it to remove the post and then remove the hardware w/a screwdriver (usually phillips) saying that...i just looked up the installation instructions for moen towel bars and it says very specifically that the posts snap or click into place on the mounting hardware...it also refers to a square hole located on the underside of the post. perhaps we are meant to put a small flat head screw driver in there to release the "clip" and post. here are the installation instructions: http://www.faucetdirect.com/mediabase/specifications/yb2218_5624sp.pdf
hope this helps:)
Posted on Jul 29, 2011
Whats the difference between a bath towel and a beach towel?
There are a few distinct differences between bath and beach towels like the size, thickness and colors. But they are both able to be used for both purposes. A bath towel is not limited to the bathroom and beach towels can also be used as a bath towel. Here's a guide that breaks down the differences.
Sep 17, 2013 | Home
Subzero 501F is not freezing well. Top shelf and top door shelf of freezer stock melted and began to rot. Bottom 3/4 is staying solid and frozen.\r\n 22year+ old unit. Had a 25 year old one at other house...
sounds like you have a bad evaporator fan motor,heat rises,if the fan isn't blowing the cold air will settle to the bottom and the top will be warm,also when was the last time you cleaned the condenser coil ?very important to do this at least once a year, shut down the machine,remove the front grill,remove the cover on the left side,,with a shop vac and brush attachment vac off the face of the coil ,now get a towel and cover the cabinet where the front grill was, you can open the door,stick the towel in and close the door to hold the towel in place,set the shop vac up to blow and blow through the right side of the coil,the towel will stop all of the dust from blowing into your kitchen,do this a few times,remove the towel and vac up all the dust that blew out of the coil,set the towel up again and blow through the other side if you can and blow into the coil where the fan is,do that a few times,you can hang the towel and just blow into the cabinet so all the dust that you can't vac up off of the walls and behind the compressor will blow forwards,also i've found some coils loaded with grease,people don't use the hood vents when they cook the oil and grease floats into the condenser fan in the subby and gets into the coil,if so spray it down with grease lightning or any kind of chemical that cleans grease,wipe it down and blow through it a few more times,gotta have good air flow in there or you'll be changing out the condenser fan motor or compressor.from what you discribed check the evap fan motor and clean the coil at least once a year
Jun 15, 2011 | APW Wyott SubZero Refrigerator Freezer...
Xbox 360 console will not show video or audio on hdmi or regular video cables on any tv. console is on and running. before it stopped the picture was distorted.now will noy show anything.how to fix?
xclamp fix,the thermal paste on your heatsinks needs replacing,just done one the same last week,it had no picture but had sound and no light on red ring but sound went off shortly after.You can learn how to do this on youtube,just search xclamp fix and plenty will show,and buy a xclamp kit off ebay,will cost about £2,if console is still under warranty for the first year its covered but if its past the first year the extended 3 year warranty dosnt cover this repair.They will charge £81 for them to fix it.And dont do towel trick it will get it working again but only for a few days and will do more damage to console
Feb 11, 2010 | Microsoft Xbox 360 Console
BOUGHT NEW CARTRIDGES (BLACK & COLOR) COST $70!! WILL NOT PRINT. SOUNDS LIKE PRINTING BUT BLANK PAGES COME OUT. . IS THERE A WAY TO CLEAN- UNCLOG PRINTHEADS MYSELF WITHOUT TAKING TO SERVICE MAN. CAN'T...
There are a few things you can do yourself to try and get the print heads flowing again, but they won't give you as good of results as a professional cleaning or new print head. I would say that the print head is most likely clogged if you let the machine sit for more than a few weeks without printing on it. If your last set of cartridges worked fine and then you immediately put in new cartridges and it didn't print, I would say the print heads may not be clogged but expired (no amount of cleaning will get them working again). To clean the print heads yourself first rub off any accumulated ink with a warm water soaked paper towel. As a check to see how your cleaning progress is going press the print head against a dry paper towel. You should see distinct entire lines for each color. You can then try resting the print head on a paper towel soaked in warm water to hydrate the print head. If no ink soaks into the towel at all after a few minutes the print head needs more cleaning than you can do yourself. Unless you know someone with a hand held garment steamer with a narrow nozzle on it you can steam the print head to loosen up the ink stuck in it.
Feb 03, 2010 | Brother IntelliFAX 1840C Plain Paper...
Petrol smell in cabin when air conditioning heater on, general petrol smells
check for fuel leaks around filter or cracked gas line. best way to tell is wrap line with paper towel. run engine for a few minutes and then check towel for gas. move until you find area of leak. good luck
Nov 12, 2009 | Saab 9 5 Cars & Trucks
Won't print black ink
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........
Unplug the Power Supply from the printer.......
Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button..........
Now the Printer will ask for the Date Time and Country Language.........
Set everything up......
Now try to Print i am sure it should work..........
Good Luck............
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Jan 10, 2009 | Warmrails & Satin Nickel Towel Warmer &...
Printer doesn't print even with new ink cartridges.
Remember to remove the Seal Tape from the Top of the New Ink Cartridge as well as from the Bottom ! !
If a “Head Cleaning” cycle makes the Test Pattern worse, STOP.
Disconnect the Printer from the Computer.
Press the “Cartridge Change” button for ~ 3 Seconds.
When the Ink Cartridge Carriage travels to the Changing Position PULL THE POWER PLUG (NOT the “OFF” Switch). The Ink Cartridge Carriage should now Slide Freely on the Rail as long as it isn’t pushed to the Right so that it goes under the shelf to the “Homed and Locked” Position.
Fold up a Paper Towel (About 1 Sheet) so that its final width is about the same as the width of the gutter under the Print Head on the Carriage and so that it is thick enough when folded to contact and lightly press on the Print Head.
Saturate the folded Paper Towel with ~ 70% Isopropyl Alcohol and lay it in the Gutter.
Manually slide the Carriage and Print Head Over the wet Paper Towel. A slight amount of drag should be experienced if the thickness of the paper towel folds is Correct.
Let the Print Heads rest on the Saturated Paper Towels for a few Minutes or Hours. Too long a Treatment may pull out all of the Cartridge’s Ink: Check the Paper Towel Frequently to Assess if Ink is Capillarying out onto the Towel.
When the Treatment appears Successful remove the Paper Towel and Clean Up and plug the Printer power back in.
Run a Test Pattern via the Computer Connection WITHOUT first running the Head Cleaning Utility.
If the pattern isn’t OK, Try Running the Head Cleaning Utility to see if it makes it Better or Worse.
If Worse, Repeat the Alcohol Paper Towel Treatment: The Paper Towel may be Gently Pulled back and forth under the Print Heads to wipe them off.
Jul 20, 2007 | Lexmark JetPrinter Z55 InkJet
No Print
remove the cartridge and set it on an alcohol-soaked paper towel in the kitchen sink for about 15 minutes. If the towel has not begun to draw ink out, then tap cartridge firmly against your other hand which is holding the towel. if still none, then try heating the alcohol to about 150 degrees and repeat. if still nothing, then ink is either spent or cartridge head is dried up. take it to cartridge world (or similar outlet store) and they can get a cheap replacement.
May 31, 2007 | Canon BJC 3010 InkJet Printer
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
