Question about Sanyo Televison & Video
Should my Sanyo tv be on HDMI......or Video 1......Video 2 ???
  • Sanyo Master
  • 10,291 Answers
Depends on what is connected to the HDMI ports on the back of the TV. Same goes for the video 1 and 2 ports. Example: If you have a blu ray player connected with a HDMI cable, then you would use whichever HDMI number you connected the cable to on the TV in order to watch the player. Same goes for video. If you have a satellite receiver or VHS tape recorder connected to video 1 or 2, toy would select them to watch that source.
Posted on Dec 06, 2016
4 Suggested Answers
  • 1039 Answers
SOURCE: Can't choose HDMI for input
On most of these sets if there is no signal present on a particular input it won't list on the input menu.
Posted on Dec 26, 2010
  • 5417 Answers
SOURCE: Hi, When I connect my Samsung
I suspect that the TV can't read the signal from the computer on the HDMI port. You would get a signal from a VGA connection. (Computers send a slightly different signal over HDMI than a DVD or blu-ray player.)
In general, when connecting a TV to a computer, turn off both devices before connecting the video cables. Then turn on the TV and set it to the source (with the no signal message). Then turn on the computer. Next set the computer to output the video on the external video port. (Depending on the laptop, you may need to enable the port in the BIOS. To access the BIOS, press Esc, F1, F2 or F10 repeatedly as you turn on the computer. The key depends on the brand of computer.) Next set the video output in the OS (depends on the OS). For Windows 7, right click on the desktop (anywhere there are no icons or running programs), select Graphics Properties and set the desired monitor choice (laptop monitor, external monitor, both or extended). Click Apply and then confirm this when the display changes. (At least this works for my HP laptop on the VGA port.; my desktop lets me change monitors under Screen Resolution.)
The manual for the TV is available here: http://www.sanyo.com.au/resources/manuals/tvs/lcd42xr9da_im.pdf .
I wish that I had better news for you.
Posted on Apr 22, 2011
draeconius
  • 65 Answers
SOURCE: I have a Sanyo DP 55441–01 TV comes on but hook an HDMI component cable no video on the screen it shows no just says no video source
Change inputs. You are probably still on tv.
Posted on Feb 11, 2015
I cannot get a picture to display on my TV with the Craig model CC4003B cable.
The USB will not display video onto your TV.
You will need to find an adaptor for this that will plug directly into your HDMI.
You need to buy a 30 pin to HDMI adapter, these are relatively cheap products that you can find on eBay.
Jun 29, 2017 | Sanyo Televison & Video
Hi-Def TV does not sinc with DISH VIP 922 receiver?
I am lost on ur question, do u mean the TV will not show anything from ur Dish? I always use HDMI cables, quick and easy hook up. now when u use HDMI cable u will need to go into your TV menu or look on the TV (Sanyo, Phillips,, etc) remote and locate the Input, Source, Antenna button. and go the the correct video stream that u have hooked up to on back of ur TV. U should see HDMI 1 HDMI 2 etc choose each one till u get a picture.
Jan 01, 2015 | Televison & Video
I have a sanyo dvd player/video cassette recorder manufactured June 2003. what do I need to be able to record tv to vcr on my flat screen HDMI tv
Wall outlet <--- coax cable --> 1-to-2-splitter <-- coax cable --> Personal Digital Video Recorder <-- HDMI cable --> TV
and:
1-to-2-splitter <-- coax cable --> VCR
May 21, 2014 | Sanyo DVW-6100 DVD Player/VCR
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
When i plug an hdmi cable into the hdmi port on my sanyo tv it says a dvi connection and not a hdmi which i have tried 2 hdmi ports and i cannot get any sound or picture on the tv
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
Jul 22, 2011 | Sanyo Televison & Video
Hi, When I connect my Samsung RF711 laptop to my Sanyo LCD-42XR9DA TV HDMI to HDMI, and source the HDMI 1 input and press OK I do not get any laptop display on the TV screen at all. I have spoken to both...
Apr 22, 2011 | Televison & Video
Sanyo DP46840 purchased less than 1 week ago from Walmart. Worked fine for first couple of days, now HDMI connections don't work. monster cable works on other lcd tv and all video sources. rest TV...
Hi gregschirk,
I bought the same model and I am experiencing a similar problem. My HDMI components worked fine before. Now both my cable box and DVD player will not be recognized as HDMI systems. It thinks they are DVI to HDMI connections. Good picture but no sound. Would like to know if there is a fix for this.
Thanks Gilbo72
Nov 27, 2010 | Sanyo Televison & Video
When i first turn on the tv it displays the ''Sanyo'' logo and then goes black. I am still getting sound though, but no picture. Sanyo DP19649
First make sure your HDMI cable is connected from the Cable to the TV; then on the TV Menu check the input; should have a choice of items like, Air, Cable, HDMI, Aux...if you do have an HDMI cable connection, select HDMI and indicate which port #; it could be listed like HDMI/DTV 1 or HDMI/DTV 2; good luck
Aug 11, 2009 | Televison & Video
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Televison & Video Logo
43 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
