Question about Xerox WorkCentre 6505DN
Xerox workcentre 6505 My printer dosn't print it shows ' load manual feed slot' How do you fix this problem When copying it works perfectly.
Changed the option to random source after receiving feedback Yet it did not work Change paper source. Probably on computer in printing preferences If it works copying then it most likely is a setting in the computer . Click on print and there should be a printing preferences option comes up before you commit to sending the print to printer.
3 Suggested Answers
  • 2072 Answers
SOURCE: Replace Drum
Start by trying this.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
      [_]
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Posted on Jan 08, 2008
  • 239 Answers
SOURCE: Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Posted on Sep 15, 2011
change paper source. Probably on computer in printing preferences
Dec 06, 2016 | Xerox Office Equipment & Supplies
Xerox black developer fade printing
Try this: http://www.fortwayneprinterrepair.com/wordpress/2014/03/17/xerox-phaser-6500-workcentre-6505-light-print-issues
Apr 25, 2014 | Xerox 6500/N Phaser Laser Printer
Not printing color correctly
try disconnecting the printer from your computer then uninstall the printer and reinstal it again the reconnect the cord from the printer to the computer and try that
Feb 26, 2014 | Xerox Laser All-In-One Machines 6505/N...
Scan documents on the 6505/DN using my pc or mac, what do I need from xerox
copier/scanner should do the trick and the new product will contain all the equipment.
Oct 17, 2013 | XEROX - COLOR PRINTERS 6505DN 6505/DN...
Have a Xerox 4118P WorkCentre that I just received yesterday. Copies were perfect yesterday, today they are blank. Very low copy volumn thus far. What could cause it to suddenly print blanks?
Pick up the phone and call the company that sent you that printer and have them send you another printer or someone who can fix the printer.
That's what you warranty is for.
Better still, return the defective printer to Xerox and then purchase a Lexmark printer. :)
Don
Oct 28, 2010 | Xerox WorkCentre 4118P All-In-One Laser...
Xerox M15 Prints dark only on copies
If your on maintenance tell them you want a replacement. If you have a maintenance agreement you are entitled to an identical replacement. Write a letter, with the serial number, peoblem and tellt them you want to exercise your TSG agreement. Total Satisfaction Agreement.
Not fixing it is rediculas.
Jan 23, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Envolope Printing
The XD100 has a manual feed on the right side of the device. You can slide the guides to fit the envelope. Use the envelope printing in your program and I believe you need to specify the size of the envelope in the driver. I think you want to feed the envelope face down (side to be printed down) to have it print on the correct side, but I could be wrong. One way to check of course, try it one way and if it prints on the wrong side, flip it over. There may be an image on the feed slot that shows which side to use.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre 6505DN Logo
113 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
