Question about Epson ACULASER CX11NF All-In-One Printer
E511 my problem cx11nf E511 whaT İS PROBLEM
  • ali assık Jul 20, 2009
    what is this problem
  • 163 Answers
E511 is a TRO sensor error (cannot detect rotation of PCU belt), don't panic its probably just a dirty sensor. Turn off & raise the scanner unit fully & open the top printer cover. Lift the orange lever and lift the PCU out of the printer using the strap. First of all turn the PCU onto its back but avoid any bright light on the blue roller (it's called the "Drum" and it is light sensitive and very easily scratched so be careful with it and avoid touching the blue surface if possible). Rotate the white plastic gears at the ends of the drum until a little silver square appears in the cut-away section of the cover, this reflects the light onto the sensor so make sure it is cleaned with a soft cloth. Next look inside the printer and you will see a metal strip running across from side to side, mounted on this is the TRO sensor. Give this a clean also with the cloth. One more thing to clean is the sensor at the back, you will see a small black plastic spring loaded lever, push this down and wipe the sensor. Do not try to lift the lever back into position, it will spring back when the PCU is refitted. Refit the PCU, close the covers and give it a try.
If still not working the cause is either a faulty MCU board or possibly a faulty PCU, but to be sure it will need checking by a repair tech as diagnosis by email is difficult.
Good luck, please take a moment to rate this solution, thanks.
Posted on Jul 20, 2009
I am getting an error message of E 511 what does this mean and how do i fix it? can it be bypasses? how do i reset the unit? Thanks
Hi Collin,
E511 is a TR0 Sensor Fault. This is commonly caused by:
Photoconductor Unit
SENSOR TR-0
HARNESS-ASSY XERO
MOTOR ASSY P/R
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
This is not Diy, I've advice you to send the unit to your local Epson Service center.
Hope it may help you.
Have a nice day!
Feb 12, 2011 | Epson ACULASER CX11NF All-In-One Printer
Error service req E511, all lights flashing
Possible parts that caused the error
1 Photoconductor Unit 2 SENSOR TR-0
3 HARNESS-ASSY XERO 4 MOTOR ASSY P/R
5 HARNESS ASSY MAIN 6 PWBA MCU
7 LV/HVPS
Dec 28, 2009 | Epson ACULASER CX11NF All-In-One Printer
1. Your website has a mind of it's own. Try typing in 'Service Req E511' & the site scrolls on it's own, not allowing me to select anything. 2. I have the above message flashing. After waiting 5 days...
Hi Sharon
I wish some of the users posting questions here had minds of there own.
Anyway,, That issue you're having doesn't happen on my machine, I'm able to type willy-nilly (and a whole lot more).
There's a bunch of answers relating to the E511 message on the Epson pages
just click here http://www.fixya.com/search.aspx?cstm=0&_s=E511
hopefully something there will help.
Oct 08, 2009 | Epson Aculaser C1100 Printer
Epson schematic (e511 error)
Hi-
Try reseating all the toners, as well as the photoconductor unit. If all fails do a reset using the panel. Call manufacturer for 562-276-4382 for step by step instruction.
Hope this helps
Oct 10, 2008 | Epson ACULASER CX11NF All-In-One Printer
No functions are working, error code E511 shows in dialogue box
E511 is in regard to the photoconductor unit. There may be the need to clean the black belt from dust accumulation (other users have reported success by that) whilst I had success by cleaning the surface of the optical sensor on the left, accessible after lifting out the photoconductor. Keep the photoconductor shielded from light while you do this. It usually about stray toner accumulated on surfaces within the printer. Be careful how you remove "dust", a vacumn cleaner can catch fire because the dust is susceptible to electrostatic charge build up.
Hope this helps.
Jun 22, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson CX11NF Error Message Service Req E511
This is from the service manual
Service Req E511
�� Possible parts that caused the error�� Troubleshooting
�� Photoconductor Unit �� SENSOR TR-0
�� HARNESS-ASSY XERO �� MOTOR ASSY P/R
�� HARNESS ASSY MAIN �� PWBA MCU�� LV/HVPSStep Check Yes No
1 Check of Photoconductor Unit attachment
Re-attach Photoconductor Unit.
Does the error recur when the power is turned
ON?
Go to Step [2]. End of
procedure
2 Operation check of Photoconductor Unit
Is the Drum of Photoconductor Unit rotating?
Go to Step [3]. Go to Step [10].
3 Check for dirt on silver seal on Belt in
Photoconductor Unit
Remove Photoconductor Unit.
Turn gear of Photoconductor Unit until silver
seal attached to Belt can be seen.
Is silver seal dirty?
Replace
Photoconductor
Unit.
Go to Step [4].
4 Check of SENSOR TR-0 (TR0 Sensor)
Is SENSOR TR-0 attached securely?
Go to Step [5]. Re-attach
the SENSOR
TR-0, and go to
step [5].
5 Check of dirt and foreign bodies on surface
of SENSOR TR-0
Are there any dirt or foreign bodies on the
SENSOR TR-0 surface?
Clean to remove
any dirt or
foreign bodies,
and go to step
[6].
Go to Step [7].
6 Does the error recur when the power is
turned ON?
Go to Step [7]. End of
procedure
7 Operation check of SENSOR TR-0
The voltage of P416-2 ↔ P416-3 on PWBA
MCU is 5 VDC when silver paper or other
reflective object comes close to the sensing
area of SENSOR TR-0, and is 0 VDC when
the object is released?
Replace PWBA
MCU. (p.404)
Go to Step [8].
8 Check of 5 VDC power supply to SENSOR
TR-0
The voltage of P416-1 ↔ P416-3 on PWBA
MCU is 5 VDC?
Go to Step [9]. Go to Step [14].
9 Continuity check of HARNESS-ASSY XERO
Disconnect the P/J416 from PWBA MCU.
Do all of the wiring below have normal
continuity?
J416-1 ↔ J108-3
J416-2 ↔ J108-2
J416-3 ↔ J108-1
Replace
SENSOR TR-0.
(p.361)
Replace
HARNESSASSY
XERO.
10 Check after replacement of MOTOR ASSY
P/R
Replace MOTOR ASSY P/R. (p.398)
ON?
Go to Step [11]. End of
procedure
11 24 VDC power supply check to MOTOR
ASSY P/R
Disconnect P/J201 from MOTOR ASSY P/R.
The voltage of J201-1 ↔ J201-2 is 24 VDC?
Go to Step [12]. Go to Step [13].
12 Continuity check of HARNESS ASSY MAIN
Disconnect the P/J403 from PWBA MCU.
Is the continuity normal between all terminals
of J403 ↔ J200?
Replace PWBA
MCU. (p.404)
Repair broken
or shorted part.
13 Continuity check of HARNESS ASSY MAIN
Disconnect P/J502 from LV/HVPS.
continuity?
J502-9 ↔ J201-1
J502-10 ↔ J201-2
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
14 5 VDC power supply check to PWBA MCU
The voltage of P410-3 ↔ P410-4 on PWBA
MCU is 5 VDC?
Replace PWBA
MCU. (p.404)
Go to Step [15].
15 Continuity check of HARNESS ASSY MAIN
Disconnect P/J410 from PWBA MCU and P/
J502 from LV/HVPS.
continuity?
J410-3 ↔ J502-3
J410-4 ↔ J502-4
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
May 22, 2008 | Epson Aculaser C1100 Printer
Service reqd E511
I was able to get hold of a schematic diagram to locate the part number for sensor :
part code 2090463 SENSOR TR-0
When I inspected the original part the pcb was cracked therefore the sensor was unable to dectect the 'mirror' which is a silver square located on belt on photo con unit.
If you require a copy of the schematic diagram (pdf) let me know an address to send it to.
Regards
Rob
May 22, 2008 | Epson ACULASER CX11NF All-In-One Printer
Service reqd E511
E511 is a TR0 Sensor Fault. Can be caused by:
Photoconductor Unit
SENSOR TR-0
HARNESS-ASSY XERO
MOTOR ASSY P/R
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
Not really something easy to fix at home.
May 21, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
287 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
