Question about Life Fitness Exercise & Fitness
Life fitness powermill shows motor disable - Life Fitness Exercise & Fitness
  • Hani Zaid
    Hani Zaid Mar 04, 2017
    Did you find a sloshing
  • Life Fitness Master
  • 6,694 Answers
If you wish to get some details about treadmill repair; check the site linked here. Pull up older posts.
Posted on Dec 06, 2016
E7 Error Code on BladeZ Fitness Powermills Treadmill
Hello, E7 error means:
- Elevation Motor Elevation Motor out of
Replace Elevation Motor
- Display Doesn't Lit Up
On/Off switch Check if unit is turned on
Insufficient Power Source Plug unit in a dedicated
120V, 20Amp Outlet
Line Cord Damaged Replace Line Cord
Fuse Check Fuse on MCB
Here is website with users manual and troubleshooting>
May 19, 2014 | Bladez Exercise & Fitness
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
Motor disabled appears after a use of 4-5 minutes and machine stops
my Life Fitness 95 Ti can not go faster then 10 km/h.
Please advice
Jun 25, 2013 | Life Fitness 95Ti Treadmill 95 Ti
My treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
May 04, 2012 | Life Fitness T3 Treadmill with Advanced...
The screen reads "unit immobilized
To Get to the manager and check for disabled items.
To enter the Systems Options Menu:
2. Touch the Life Fitness logo in the upper right hand corner of the screen three consecutive times
go to configuration
Allows authorized personnel to access all configurable settings of the unit. Configurations which should only be changed by qualified technicians are password protected.
Manager Vivo/Network
Manufacturer , Create Your Own
Media Center , Clock
Custom Workouts
Touch Screen Configuration
Export / Import Settings
The console manual will show you all the default values .
Feb 01, 2011 | Life Fitness 95Te Treadmill
My life fitness hr9500 is showing diable motor on the display and after sometime it will resume, then it repeats the same again. how do i solve this victoria
just change motor brushes and go to service menu(by clearing and pressing pause button)
press speed up button and go to system communication check
it will tell everything on there
let me know
Nov 19, 2010 | Life Fitness 9500HR Next Generation...
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
Life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Feb 28, 2009 | Life Fitness Remanufactured Next...
Exercise & Fitness Logo
294 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
