Question about Tablets & eReaders
How do I update my 4.4 zeepad - Tablets & eReaders
My grandson dropped his Zeepad and the screen cracked. where can we take it to be repaired or mail it in for a replacement?
With basic "lesser brand" Android tablets such as the Zeepad starting from about USD40 from the bigger online retailers, it is unlikely to be worth reparing the cracked screen. BTW, a repalacement screen by itself CAN be bought for about USD25, from which you will probably also conclude that a repair is uneconomical.
Sep 13, 2017 | Tablets & eReaders
Zeepad instructions
You will be lucky to find any instructions for this tablet on line.
I think these are imported directly from the supplier and onsold by the supermarket chains.
But if you are after connection with PC, then you need a microUSB cable and hopefully once you connect to PC the PC software will recognize it and connect to the services.
Try this link for some specification information and instructions on how to update the firmware on the tablet. Make sure you save your data on the PC before you update.
http://zeepad.net/7.0.html
Aug 01, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
IS THERE A MANUAL FOR A ZEEPAD 7 TABLET
Go to Settings -> Storage -> Factory Data Reset.
If that is not an option, then:
1. Power of the device completely.
2. Hold down both volumes and power at the same time. This should bring up an image of an android on its back, opened up.
3. Press both volumes at same time to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
5. Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
6. Your zeepad should now be reset
May 25, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
How can I reboot my Zeepad?
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
May 16, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
Cant play videos
google adobe flash player and install or go to google play and instal it from there
Dec 29, 2013 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
Why wont my camera work on my brand new zeepad 7.0?
could be corrupted data or bad app,going to settings and reset to factory default that should fix corrupted data, if it still persists check for firmware updates in the settings, then check for app updates. if it still exists after that return back to factory for warranty repair
Dec 28, 2013 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
I cant figure my zeepad password out and it wont unlock
do a hardreset, this erase all if dont work update the firmware.
more instructions here : http://zeepad.net/7.0.html
Apr 21, 2013 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
I cant remember pass word to my zeepad
Go to www.zeepad.net click on the picture of your device. Download the device driver, loading program, instructions and the firmware for your zeepad. Reinstall the firmware this will update and bring your unit to
Like new
Mar 21, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
How do i reset a zeepad
To reset your zeepad you must reload the firmware to it. For instructions go to
www.zeepad.net
Jul 17, 2012 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Tablets & eReaders Logo
37 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
