Question about DIGITECH Music
Hi I'd like to calibrate my Digitech QM1589 and I also need instructions on how to operate it. Can you help please
HOW DO I SET UP MY Digitech 1500, TO CHECK MY aa & aaa BATTERIES ?
Jan 27, 2018 | DIGITECH Music
How can I get instruction manual for digitech xc0430 weather guage ?
Please kindly check - here is the list of Digitech devices. Hope you can get here the one you need or a similar one.
Oct 20, 2017 | DIGITECH Music
Hi I have a vhf digitech AM-4071 wireless microphone system and the problem is that both microphones are going only through one RF, on the transmitter. The second mic goes but its not receiving on tr
You need to check that they are both operating on different channels there should be a switch or POT on the microphone and possibly one on the reciever. If they are static or preset you need to swap one for the other channel. Some (usualy cheap) mics have a preset or static channel often ch-A and ch-B, there should be one of each in the box. If you bought the extra body packs they will also come with the preset channels.
- thegorisb
Instruction manual for Digitech QM 1324
Try these links.
Copy and paste these links to the address bar to your borwser and press 'Enter', if you can't diretly go to ths links.
Feb 27, 2012 | Music
My rp90 reads out pd when i plug it in and is stuck in this pd mode and doesnt let me play anything how do i unstuck it from this pd mode
Try a factory reset. This is the procedure
1. Press and hold the Store button while powering up the RP90.
2. When the display prompts you with FR, release the Store button.
3. Press and hold the Store button for 3 seconds until RS appears in the display and release. The Factory Reset procedure takes approximately 10 seconds.
4. Once the factory reset has finished you will need to calibrate the Expression Pedal.
May 14, 2011 | Music
How do you hookup a digitech vocalist performer to a pa board
What mixer will you be using it with and how many channels will you need to use it on. After I know this info I can help you.
Jan 16, 2011 | Digi-Tech Digitech Vocalist Live 4...
I need to know how to restore factory settings on digitech RP RP-90
Here is the link to your manual if you don't have one: Page 34 tells you how and don't forget to calibrate the expression pedal. Page 35 tells you how. Hope this helped.
Nov 09, 2010 | Music
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I need instrution manual for a digitec rp100a guitar effect
The manual you are looking for can be found right here:
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 22, 2010 | DIGITECH Guitar Effects Model No Ddm
Hi! Im looking for the service manual or schematic for the Digitech Valve Fx guitar eff.proc. The unit can turn on, and in bypass mode has a clear sound, but in normal operation has terrybly noisy, It...
can be too late but one never knows:
you must simply answer the questions to be able to download.
Philippe to France
Jun 10, 2009 | Digi-Tech Digitech Vocalist Live 4...
Music Logo
14 people viewed this question
Top DIGITECH Music Experts
Michial Gueffroy
steve cannon
Level 1 Expert
Are you a DIGITECH Music Expert? Answer questions, earn points and help others
